Started this idea when i was sitting in the Pits @ National Trails (for what Seemed like Hours)
First Run was always the best Run (how to get rid of the Heat between Runs)...
You must have a custom Grill to attempt this Upgrade, Will not work with the stock grill....!
http://www.siliconeintakes.com/electric-radiator-cooling-fans/intercooler-fans-p-1024.html3 - 7" Fans (12VDC, 1100 CFM X 3 = 3300 CFM ) "Will be powered by a Jump Pack" Under 100.00 Delivered.
2 - Aluminum L Channel 3/4" X 3/4" X 20" Long (i bought a 8' Piece) 20.00 Max Delivered
8 - NO 10 X 1" Long Phillips Head Screws With Lock Washers
3 - 1/4" X 1" Long Hex Head Bolts With Lock washers
2 - 1/4" x 1.5" Long Hex head Bolts With Flat Washers
Tap and Dies for the above, Portable Drill & hand tools
Wiring Quick Connectors (Male and Female), Wire and Fuse Block (20 AMP Fuse)
3 - 1/8" X 2" x 3" Thick Rubber Strip for bottom of Aluminum channel
Not Going to do a Write up (unless Someone actually wants to do this)
We did it with the Grill and bumper cover ON, and IT was Trial and error PIA,
But now that it is done "with Instructions" it took about 4 hours Total to complete.
total Parts Cost Approx. Under 150.00, the pictures tell the story:
