UPDATE I noticed the bouncy feeling has definitely subsided and the ride feels so so such better .IMHO and needs to settle in. Z
I also contacted Tire rack and here was there response!!! hope this helps someone justify there decision on purchasing a set of H&R Springs.
H&R Sport Spring Set
FRONT AND REAR
Ride Height: Moderate Lowering
Manufacturer Part #: 51626Note: Avg low 1.4"F & 1.5"R.
Qty:Per Kit:
$231.00 Availability: In Stock
Free Shipping
Add to CartSave for Later >
Description
Lea en español
H&R Sport Springs are designed and engineered for each particular application to lower the vehicle's center of gravity and reduce body roll. They offer the correct spring rate for low, aggressive looks, high performance handling and no ride harshness! Stock ride comfort is retained while a lowered ride height between 1.25" – 1.8" on average can be expected.
GillMinimize Click to pop out End conversation
Info at 18:09, Oct 1:
Thank you for choosing to chat with us. A sales specialist will be with you shortly.
Info at 18:10, Oct 1:
You are now chatting with Gill.
Gill at 18:11, Oct 1:
Hi, how can I help you today?
ZSHO at 18:11, Oct 1:
hi there! I purchased a set of the h&r springs 51626 and installed new struts,shocks and it appears there is a bouncy ride.
Is that normal? do they need to break in? thanks so much
Gill at 18:12, Oct 1:
Yes, they will need a few hundred miles to settle in.
