Started by AJP turbo, August 29, 2017, 10:24:03 PM
Quote from: AJP turbo on August 29, 2017, 11:44:32 PMThank you folks...I saw a few links but some didn't work and some were really incomplete....Just figured I'd ask because some of you are pretty resourceful. I can't remember what I looked at a couple years ago but it would show you the actual sticker...It's gone nowBuying a fusion tomorrow...I know longer want the truck anymore but it is really nice and the 2.7 satisfied very well for...Nice blend of power and economy if you haul less than 7500lbs.I had it on a dyno and the track and ran full E85 so one day when I get time I will post some goodies
Quote from: AJP turbo on August 29, 2017, 10:24:03 PMAnyone know a good site for a Ford window sticker generator?...I used to know one but I can't find it and another that I recently found doesn't seem to be legit and you have to sign up for stuff...I figured there is a better way.
Quote from: SHOdded on August 29, 2017, 10:47:42 PMThese sites do not work anymore. Ford has cut access off, so now you have to go thru a dealer.ETIS is also undergoing changes. Only a fraction of the info shows up when searching by VIN.
Quote from: donky4444 on August 30, 2017, 01:48:13 PMQuote from: SHOdded on August 29, 2017, 10:47:42 PMThese sites do not work anymore. Ford has cut access off, so now you have to go thru a dealer.ETIS is also undergoing changes. Only a fraction of the info shows up when searching by VIN.I just tried the link I posted and it pulled up the window sticker. Sometimes it says its not available yet but most of the time it works. I just pulled up a 2014 Focus on a local lot and it worked.
Quote from: Night Hawk on August 30, 2017, 03:32:47 PMhttp://www.fordshowparts.com/store_contents.cfm?product_id=6989
