Its taken a bit of time to get there, but these are pretty solid.. Desire TIP is set to 15psi and spark is capping at 28 degrees.. no knock anywhere to be found.. one is a third gear pull and the other is a multigear without launching.. Brad has thrown some special sauce in this tune to help with traction that appears to be working..
We are using throttle control at this point not to assist with fuel pressure, but I believe will help with keeping those massive boost spikes from causing traction issues... my car has always had massive boost spikes that if not controlled cause problems...
Track this Thursday!
