I checked
Tascaparts.com and used the words "Center Storage Console Door" & it returned with a few different options.
None of them however had any images displayed, or associated with each part listed.
The prices varied from $25 on the low end, to like $130-ish or so on the high end.
It's an easy fix, as you just pop up the small narrow plastic pieces on either outer most edge of the console, which will then expose the (I believe 8mm) sockets holding each compartment down.
Good luck.
