Ecoboost Performance
Troubleshooting, Maintenance, TSB Articles
Troubleshooting
P0455 - Evaporative Emission System Leak...
Started by MeanKS, June 21, 2017, 08:48:47 PM
MeanKS
Sr. Member
Ecobooster
Engine light came on and this is the code Autozone pulled up.
How bad is this? the car is running pretty normal, only thing i notice is slight hesitation at idle on occasion.
my engine is still under warranty (Ford replaced it due to a thrown rod almost 2 years go), but knowing my luck this will probably not be covered.
How long can i go before addressing this? I just had a very big expense (house related) so the wallet is a little tight atm...
MKS-EB...
Forum Supporters
Re: P0455 - Evaporative Emission System Leak...
June 21, 2017, 09:15:37 PM
Probably purge and/or pcv valve issue. As an emissions issue, the problem should be covered under emissions warranty, which is generally longer than the powertrain warranty. DIY fix is not that expensive, but have the dealer fix it.
Troubleshooting
