Speed Difference - 10 MPH Higher at all Speeds.
Started by irondoor19, June 13, 2017, 10:33:06 AM
irondoor19
OK:
So after the New ECU (used w warranty from LKQ , Cheap like 125.00) and the
Flash from the Dealer (not SO Cheap)...
The Car is showing 10 MPH Higher at all Speeds above 25..
So 30 is 20 Actual,  100 is 90 Actual VIA GPS... I felt it was off when i was driving it.
called the Stealer Dealer, and they said some crap about tire Size, and did we change the
rims (it Came with 20's) so we are lost....any suggestions from the Group....???
TopherSho
Quote from: irondoor19 on June 13, 2017, 10:33:06 AM
OK:
So the #1 question is when you turn it on and it does the gauge sweep... where doe the mph needle site at idle?
Best 0-60 public road 4.35s
Does your tuning device show the correct speed?  If so the ICP may need to be recalibrated.
TSS
I'm not at all trying to be smart, but have  you just double checked that you have it to miles per hour and not kilometers per hour?
Brucelinc
Quote from: TSS on June 13, 2017, 12:44:45 PM
Lol...that was my first thought, too.
irondoor19
OK:
Gauge sweep goes from 0 to 140, AND ends up back @ 0
Set to Miles per Hour, otherwise the Difference would be MUCH greater
How about the rear end ratio, PP versus Non PP....?  IN THE ECU...?
Stump the band..this is a brain buster...
Brucelinc
2.77 gear for non PP and 3.16 for PP could explain it.
TopherSho
maybe not,  (20 X 1.05) = 21mph X 1.125 = 23mph-ish.   He is reporting 10mph diffs.  It has to be the speed sensor?  Do the sho's have a speed sensor?  wrong voltage back up to the ecu/cluster ?  missing filter or resistor issue ?
If Ford installed it they should fix it for free.
irondoor19
Quote from: SHOdded on June 13, 2017, 11:36:01 AM
tuning Device is Back at SCT getting unlocked due to the ECU lockup,
and when we get it back, we will investigate that
irondoor19
Quote from: irondoor19 on June 14, 2017, 11:05:48 AM
HOOKED UP TO SCANNER: Car is recording actual mileage internally, but Speedo is off,
Did some resets to see if it comes up correct... will be GPS in later today...
ok, so the IPC needs a calibration update most likely.  Hopefully that is all.
jmr061
Considering it is a used PCM I wonder if the VID was re-written or not.
Jason
16 Edge Sport
jmr061
The PCM calculates the vehicle speed from the transaxle Output Shaft Speed (OSS) sensor input and from the tire size and axle ratio configuration in the PCM Vehicle Identification (VID) block. The PCM provides the Instrument Panel Cluster (IPC) with the vehicle speed data over the High Speed Controller Area Network (HS-CAN) bus. The IPC monitors the vehicle speed input and commands the speedometer with a corresponding movement of the pointer.
Jason
16 Edge Sport
irondoor19
Quote from: irondoor19 on June 14, 2017, 03:44:20 PM
Mileage as indicated via: GPS and Speedo
                                   17          20
                                   25          30
                                   33          40
                                   43          50
                                   52          60
                                   60          70
                                   70          80
                                   78          90
                                   88         100
WE will be getting the SCT tuner back tomorrow.....
So not a fixed mph lag.  About 12% off.  This the GPS on your phone? Ford's GPS is known to need recalibration sometimes.
All in all i say the IPC needs recalibration.
