4+X REQUIRES 93 octane fuel, and it is fine to run 93 E10 blend, which is what LME built the tune for. That blend is almost universally what is found at US gas pumps now.
But as SBS said, fuel quality varies greatly. You will have to check around to see which brand and/or which station works best for you. I try at least for Top Tier fuel, and if not possible, a very busy gas station so the fuel doesn't get stale sitting there.
http://toptiergas.comThe RACE tune, yeah you need more octane as the name implies. Since ethanol is significantly higher octane than gasoline, blending in some E85 will get you there. Don't add too much E85 though. You WILL need your MKS tuned for E85 if you do that, as ethanol is lower energy, has a different stoich, and different burn characteristics than gasoline. I think E15 is where it starts to make an impact.
