First SHO With Direct Port Methanol injection!!
Started by ZSHO, May 25, 2017, 05:32:11 PM
Here are a couple of pics of the Front wide-band 02 Sensors at 50k that were not responding correctly while on the Dyno and had LMS swap them out.
I guess with any such Mod staying on TOP of your vehicles maintenance aspect is crucial for optimum performance. Z
Here is a list of Fluids changed at roughly 30K.
1)-PTU Fluid changed at 30k with Mobile 1 synthetic.
2)-RDU Fluid changed twice using Redline Synthetic gear oil
3)-Redline Full Synthetic motor oil changed every 3K.
4)-Coolant Flushed out Twice for a peace of mind.
5)-Brake system flush using Motul Dot 4-600 Synthetic racing brake fluid.
I forgot to mention with the extra HP & TRQ had a Code C0062 (Longitudinal) Acceleration Sensor after my trip back home last week which was Funny. LMAO :rofl2:
I have been monitoring it and so far so good no Codes. Z  :)
StealBlueSho
derfdog15
Based on those O2 sensors you were running rich, like REALLY rich based on that carbon/soot buildup. I would keep an eye on your O2 sensors moving forward.
StealBlueSho
Quote from: derfdog15 on June 07, 2017, 01:02:07 PM
LMS keeps pretty close to stock AFR... which is rich.
TopherSho
Quote from: StealBlueSho on June 07, 2017, 01:18:20 PM
Is that to offset the e85 being e55-e85 depending on luck and the time of day ?
Best 0-60 public road 4.35s
StealBlueSho
Here are some updated (Topless) clean pics for yall. Z  :)
StealBlueSho
I'm in love.... it's only awkward if you make it awkward..
[FYI-Update].- Media Dept from LMS should be releasing a video very soon in conjunction with my very own build thread.  :) so-stay-tuned my friends. Z
Here's a PIC on the DYNO at LMS but due to the Fluorescent lighting it appears to look Bronze-Fire . Z
415whp.-465wtq
J-Will
whoa, thats awesome!!!
Whats the difference between the pulls on the chart?  No meth Vs direct meth or previous meth vs direct meth
3-bar
SP-542 plugs w/ GH gap
Livernois Motorsports
TimmyATL
Is LMS selling the Direct Port Methanol kit? I went to there web page and did not see anything about it. I want to change from my single port pre throttle body to the direct port with seventh nozzle.
13 SHO PP, Airaid intake, 170 T-stat, 3bar map sensor, Ecopower Parts hot side pipes, Turbosmart 7lb wastegate actuators, Stainless Works catted downpipes, Corsa cat back exhaust with Loudvalves exhaust dumps, Alky Control Meth Injection, LMS Dyno Meth tune. TSW Nurburgring  with NItto NTO5
Quote from: TimmyATL on July 20, 2017, 02:51:14 PM
IDK if they sell the Direct port Methanol setup alone but you can always try calling them or email @ info@livernoismotorspots.com .
FYI I'm relatively sure its similar to what Pro-meth and others sell just a re-branded version IMO. Z
