EBC brake kit won't fit
Started by Ryan02Stang, May 21, 2017, 02:16:17 PM
Ryan02Stang
2015 Explorer Sport
2012 Lincoln MKS ecoboost, Unleashed
2002 Mustang GT, Vortech Supercharged
Ryan02Stang
I've been researching and it says the rotors in the kit I bought are 13.3 inches, when stock is 12.8.  I've verified on several sites and it says the kit fits a 2012 MKS.  What's weird is the pads for fine.
Why the hell would they say it fits with bigger that stock rotors??
Sent from my ONEPLUS A3000 using Tapatalk
2015 Explorer Sport
MiWiAu
Do the measured diameters of the new rotors match the ones you removed?
Are you 100% sure the correct rotors were inside the box? I ordered EBC rotors online from another vendor and they were drop-shipped direct from EBC. TWICE I got the wrong rotors inside the box (box part number was correct, but the rotors inside were wrong). In my instance, the rotors were the right dimensions, but they sent the slotted-only rotors instead of the GD Sport (slotted and dimpled).
EBC finally got it right on the third try, but it took over 2 weeks to get it all sorted once I discovered the issue.
EDIT: Just saw your second post. I assume your new rotors also measure 13.3in, in which case they are likely not compatible without the proper upgrades. :/
2013 XSport
Ryan02Stang
Quote from: MiWiAu on May 21, 2017, 02:45:04 PM
The rotors are slightly bigger than my stock ones.
2015 Explorer Sport
Ryan02Stang
Any idea what those upgrades are?  If I just have to buy new caliper brackets I will.
2015 Explorer Sport
MiWiAu
Quote from: Ryan02Stang on May 21, 2017, 03:24:58 PM
Here's a thread that might help: http://www.ecoboostperformanceforum.com/index.php/topic,7016.0.html
Looks like dust shields, calipers, caliper brackets, pads. I'm not as familiar with the SHO, so hopefully someone can chime in and confirm required components for pre-13 brake upgrade.
2013 XSport
Ryan02Stang
Total BS they would sell a kit claiming it's for 2011-2012 MKS, without mentioning you need all new brake components!
2015 Explorer Sport
Ryan02Stang
Quote from: ZSHO on May 21, 2017, 05:35:56 PM
I'm seeing 325.12mm (12.8") x 30mm (1.18") referenced to the - 2012 MKS.
Z
https://www.carid.com/2012-lincoln-mks-performance-brake-kits/?filter=1&field%5B357457%5D%5B%5D=Front&manufacturers%5B%5D=EBC+Brakes
Yeah....that appears to be a different kit than the one I bought.  Hopefully they'll let me swap the rotors with the correct size.
2015 Explorer Sport
Ryan02Stang
I emailed the website where I bought them and they said EBC has fed the sites selling this kit incorrect fitment details.  They're letting me return the kit.
2015 Explorer Sport
Cool Beans.!! I did not see that part number you referenced to be compatible with your 12-MKS.!! But glad there making good on there end. Z
Ryan02Stang
Quote from: ZSHO on May 22, 2017, 08:00:00 PM
Most of the sites have it listed for 2011 and 2012 MKS's.  The website I bought from said it's EBC's fault.  Not sure how it works.
Here is a screenshot from Summit.
2015 Explorer Sport
Sweet!  EBC needs to correct their feed.
Ryan02Stang
#14
Quote from: SHOdded on May 22, 2017, 09:24:21 PM
Where did you get your part number chart above?  When I pull up that part number it's giving me the below.  It is recommending me to use the part listed for 2010 on your chart above.
2015 Explorer Sport
