Quote from: FoMoCoSHO on April 14, 2017, 03:55:03 PM
SBS, are you planning on running the new pump and full E85?
Honestly, the end goal I want is to be able to run similar to what I am running right now with a bit over 14psi and 25 degrees of spark on E20 without having to use the throttle to control the boost spikes... thats what I want the bigger pump for.. if we can increase the boost and timing on say E30 or E40 and still maintain enough fuel pressure to not need the throttle to control load even better... the meth I want to help reduce the IAT's... I want keep my IAT's low enough that the ecu wont pull spark... there for I am not relying on the Meth to provide Octane or fuel.. if I run out of meth, fine, the ECU will just pull spark...
In short..
Bigger HPFP to eliminate the need for throttle controlled load.
Ethanol to prevent knock retard
Meth to reduce IAT's so I can hold full timing at the track.
I feel this would give me a solid platform that is safe and stable.
