Recommended tire size for 20" SHO wheels
Started by metroplex, August 21, 2016, 07:10:45 AM
metroplex
My 14 SHO has the 19" wheels with 255/45R19 tires and they are solid and low-key (no complaints for traction or lateral grip). The new SHOs seem to only come with the 20" wheels with 245 tires. What's the width on the 20" wheels and will they fit 255 or wider tires?
Previously: 2014 SHO
12.4 @ 110.9 mph
Current: 2017 Fusion Sport
20x8 wheel....have been running with the eagle sport 255-45-20 for well over a year now and couldn't be happier.BTW Metroplex add your signature with your current vehicle and any mods you may have,thanks.  Z
You might find some useful information in these threads:
http://www.ecoboostperformanceforum.com/index.php/board,114.0.html
The width of the 20" wheel is 8".  255/45/20 is a common replacement size for the stock 245/45/20 tires, and usually a bit cheaper.  The widest I believe will fit is 275s, a search for that in the Wheel/Tire section should confirm.
EDIT:  Tire manufacturers recommend a minimum 9" wheel width with the 275s,
Mkt8891
Ok this may be a stupid question, did putting the 255/45/20 on the car make the tire diameter larger?  I'm asking this because I went to order 255/45/20 and the guy from tirerack said that the overall diameter would go from 28.7 to 29.0 inches and kinda talked me out of buying the tires. I wouldn't think that getting a tire 10mm wider would make the tire .3 inches taller.
FearlessAZ
The diameter does go up just a bit. If my math is right, the 245/45/20 has a diameter of 28.68 and 255/45/20 is 29.04. The difference is like .36. Think it is just about 1% change.
The 255/45/20 is a pretty common replacement. They are cheaper (most of the time) due to it being a more common tire size. It should hardly mess with your speedometer (should still be accurate to within 1 MPH).
2010 Non PP Sho. All the factory goodies. (RIP)
2015 MKS Ecoboost. All the factory goodies. (SOLD)
Wild13SHO
#5
I went to a 255/45/20 and don't care for the look.  Too much side wall, tires just look too big. If the car is stock height they do fill the wheel well a little better.
I'll be going back to the stock tire size.
The speedometer will be off 1-2 MPH as well.
Current:
2016 F150 2.7L Ecoboost.  Stock for Now
SOLD:
2013 SHO 400A, PP
Dxlnt1
I run the 275/40-20 tires. Rim is 20x9 with 39 mm offset. Tire size was cheaper price wise than most other sizes. Tire rides good, good grip. My car fully stock suspension wise and i love the profile.
Click link in signature for couple more pix
Quote from: Wild13SHO on October 30, 2016, 10:11:19 PM
Do you happen to have any pics?
metroplex
Fixing the speedo is easy if you can tune your ECU.
12.4 @ 110.9 mph
