Started by polskifacet, January 30, 2017, 10:38:51 AM
Quote from: ZSHO on January 30, 2017, 10:54:57 AMDid you have the license assembly recall done? There are two lamps which probably shorted out due to corrosion,water. Zhttp://www.tascaparts.com/auto-parts/2013/ford/taurus/sho-trim/3-5l-v6-gas-engine/electrical-cat/license-lamps-scathttp://ford.oemdtc.com/2263/14r01-license-plate-lamp-assembly-replacement-2010-2014-ford-taurus-2013-2014-police-interceptor-sedan
Quote from: polskifacet on January 30, 2017, 11:07:14 AMQuote from: ZSHO on January 30, 2017, 10:54:57 AMDid you have the license assembly recall done? There are two lamps which probably shorted out due to corrosion,water. Zhttp://www.tascaparts.com/auto-parts/2013/ford/taurus/sho-trim/3-5l-v6-gas-engine/electrical-cat/license-lamps-scathttp://ford.oemdtc.com/2263/14r01-license-plate-lamp-assembly-replacement-2010-2014-ford-taurus-2013-2014-police-interceptor-sedanI have the recall done, the housing contacts look spotless.
Quote from: SHOdded on January 30, 2017, 11:26:13 AMParking, rear, and license lamps all run off Fuse 40. So possibly the LPLs from DB are defective. Wouldn't be the first time. Do the original lights work? If so, you need to get replacements from them OR go to an alternate vendor like DiodeDynamics.com, or even Amazon (e.g., SiriusLEDs).
Quote from: AJP turbo on January 30, 2017, 12:02:47 PMIt has me curious if it could be related to your other problem....I hope it's not an electrical gremlin....Although it looks like we are on the path to find out.
Quote from: ZSHO on January 30, 2017, 11:47:28 AMDid you check #12 fuse above the brake pedal. ZInterior lights work?
