Datalog time comparisons
Started by Colorado-SHOBro, February 04, 2017, 12:11:12 PM
Colorado-SHOBro
#15
I would say you're right but the couple other locals ive talked to don't seem to have the same experience and report the best results launching around 1900-2000rpm.
12.8@108 @ 6,000ft DA.
SHOwoosh
[/quote]
Thanks for the clarity check. Also, would you mind posting some of your 0-60 logs? curious to see others. Nobody ever posts logs of a dig pull.
[/quote]
here's my last trip to the strip.I got there late so I just hot lapped it. Think I can get a little quicker with more boost on launch as there was just a little chirp on the second one.
12.93 run 1
12.88 run 2
2011 SHO PP fully loaded.
Uleashed 93 3bar. Stock everything else. Best run 12.88
Now AJP 3bar still all stock otherwise. Times to come
Colorado-SHOBro
#17
Quote from: SHOwoosh on February 07, 2017, 08:02:36 AM
[/quote]
Quotehere's my last trip to the strip.I got there late so I just hot lapped it. Think I can get a little quicker with more boost on launch as there was just a little chirp on the second one.
12.93 run 1
Cool thanks for posting these. what track and what was your da?
StealBlueSho
Quote from: Colorado-SHOBro on February 04, 2017, 12:45:24 PM
Quote from: StealBlueSho on February 04, 2017, 12:43:26 PM
Yup, I copy over the column with the time stamps next to the mph...
You didn't state what you were doing to get the items, just thought I would share how I got mine...
Here is a dig with my latest tune.. still a work in progress but we are getting to where I want to be... might need meth... this was a 4.1 second 0-60 pull... I started getting some KR towards the end which was weird but then again I was running over a bunch of dirt at the point bouncing me around... dunno if that set off the KR...
f8tlSHO
Quote from: StealBlueSho on March 22, 2017, 06:45:36 PM
How?? I can only get 4.5-4.6 on my e30 tune 14psi
StealBlueSho
Quote from: f8tlSHO on March 22, 2017, 06:47:26 PM
Are you boost braking on your launches?
f8tlSHO
Quote from: StealBlueSho on March 22, 2017, 06:55:17 PM
Some I have, but not brake boosting normally nets the same number... spins too much... right now my car is up around 26 degrees timing on e30 and 14psi... it has been throwing traction control light on 1st-2nd shift
f8tlSHO
My fastest has been a 4.4 on e20 15psi tune at the track... your not doing your testing going downhill are you?
StealBlueSho
Quote from: f8tlSHO on March 22, 2017, 06:58:58 PM
Hahaha no, not down hill... as flat as I can get..
I brake boost, launch around 2K... good tires though.. dunno... I've been racing for years... maybe 1000's of launches which equates to lots of practice? Dunno.. maybe I have a freak car? My strategy is different enough lol...
Should probably take this car to the track this year...
f8tlSHO
Quote from: StealBlueSho on March 22, 2017, 07:19:56 PM
I've been racing for about 20 years, I think it has more to do with tires and pressure, I air down at the track. What tune u running right now? My 4.4 was a 12.4 1/4 mile
StealBlueSho
Quote from: f8tlSHO on March 22, 2017, 07:22:42 PM
That's pretty quick!! Right now it's an E20 tune... datalog has all the goodies as far as boost, etc..
Tires are sport comp 2 summer performance... once temps get into the 30's they suck bad.. once warmed up they hook great...
That 4.1 was with tires at 35psi... no joking...
StealBlueSho
Here is another datalog... its a 4.2 0 - 60 with LMS 4+x race tune... its a good solid tune as well.. no E blending..
f8tlSHO
I just tried to do a 2k launch spun like crazy and missed 2nd gear.... no love... lol
StealBlueSho
Quote from: f8tlSHO on March 22, 2017, 08:59:41 PM
Lol, might be too cold outside? My best times are when ambient temps are between 60-75... after the wheels have warmed up a bit...
The LMS run at 4.2 was a bit cold outside.. the denser air helped because honestly, I have not been able to get that low on LMS's tune but a couple times...
Brads tune I am able to replicate 4.1 often.. pretty consistent..
When I ran the wastegate mod I was getting 4.3 just by standing on it.. no power braking... if I tried to power brake I would spin too much.. never dialed in the launches with it....
Either way, I'm sure you are right there.
f8tlSHO
Quote from: StealBlueSho on March 23, 2017, 06:30:16 AM
I think it was mid 20's outside... after this episode I think the car was in fwd limp mode after this ridiculous spinning episode. In fwd this car is useless... lol
