Any sponsors sell a OEM PP transmission cooler kit?
Started by MTaurusSHO, January 22, 2017, 08:38:28 PM
MTaurusSHO
Looking to install the OEM PP transmission cooler on my 2013.
2013 Tuxedo Black Non PP SHO
AirAid, LMS Tuned, Plugs and T-Stat.
2002  MMM Z28
F1 Procharged 408ci
None that I am aware of.  There are a couple of writeups in the HOWTO section for trans cooler stuff, albeit primarily for 2010-12.  You could try simply replacing the thermostatic valve for some improvement right off like Colorado-SHOBro did.
http://www.ecoboostperformanceforum.com/index.php/topic,522.0.html
If you have ACC, putting on the full system might be an issue, but this is how polskifacet did it:
http://www.ecoboostperformanceforum.com/index.php/topic,5389.0.html
Do you intend to track the car, or does your car sit in traffic all the time, or ...?
Colorado-SHOBro
i got the pp trans cooler(just the front heat exchanger,not the lines cuz i won't use them being i have ACC) from car-parts.com for $50 shipped. mine came off a PI sedan
12.8@108 @ 6,000ft DA.
BlueSHO
2016 SHO Blue Jeans
2001 Lightning
1996 Mystic Cobra
