May 27, 2020, 02:28:48 am
Author Topic: Urgent Air Raid Install Question  (Read 3331 times)
Offline Freshwes
  • Newbie
  • Thank You
  • -Given: 7
  • -Received: 2
  • Ecobooster
« on: January 17, 2017, 07:50:33 pm »
Hi Everyone,
Just received my 450-260 air raid kit for my 2013 taurus, and it appears that the IAT sensor harness is not long enough to reach.
Is it safe to splice in new wire to extend it? car is currently apart.  It also seems like the IAT is slightly loose in the kit as well, although its secured by the washer as specified in the instructions.
Any advice would be appreciated.
Thanks,
Steve
Offline AJP turbo
  • SCT dealer and custom calibrator 3.5 ecoboost specialist
  • Vendor
  • Elite Member
  • Thank You
  • -Given: 133
  • -Received: 1168
  • Log Warlock
Re: Urgent Air Raid Install Question
« Reply #1 on: January 17, 2017, 07:59:03 pm »
I wouldnt touch the wire...you should be able to cut the loom a little or find the next clip that secures the wire and unclip it or cut a zip tie to gain some length without splicing wires
Offline derfdog15
  • Elite Member
  • Thank You
  • -Given: 138
  • -Received: 441
  • Ecobooster
« Reply #2 on: January 17, 2017, 08:02:49 pm »
Pretty spot on, there is a clip on the side of the engine, if you trace the wiring back a little from the sensor. Unclip it and you will have enough length, that is how mine is currently set up.
As for the sensor, is the stock O-ring in good shape? Mine broke when I pulled the sensor out of the stock housing. If it is damaged it may not be sealing fully. However, with the sensor properly oriented, and the washer and bolt in place you should be fine. If the O-ring is damaged, replace it later on and the sensor will fit tighter. I used an O-ring slightly larger than the stock size, with a dot of oil on it, then pressed the sensor in tight, IMO even without the bolt my sensor will not be going anywhere
Offline Freshwes
  • Newbie
  • Thank You
  • -Given: 7
  • -Received: 2
  • Ecobooster
« Reply #3 on: January 17, 2017, 09:27:56 pm »
Awesome, Thanks Guys.
Was able to unclip it in a 2 places and it reaches.  Still makes me a bit uneasy that i had to loosen it. but i guess it'll work.
As for the o-ring, that would have been my next question, doesn't seem to seal 100% however its tight and in place.
Is the o-ring a ford part number? do i need to replace the sensor or would a regular o-ring suffice.
Thanks Again
Offline derfdog15
  • Elite Member
  • Thank You
  • -Given: 138
  • -Received: 441
  • Ecobooster
« Reply #4 on: January 17, 2017, 09:38:37 pm »
Thanks Again
Wire wise, mine has been connected as I described for the last ~5k without issue.
As for the O-ring, I used a standard black O-ring. It took some trial and error because I broke the stock one, and threw it away absent mindedly. I ended up using a standard black O-ring, that felt a bit thicker than the stock one. Like I said, I had to put a dot of oil on the O-ring, and then push the sensor down with a screwdriver to get it to pop into place. Mine feels very very snug. Good luck!
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • New York SHO
  • Thank You
  • -Given: 1932
  • -Received: 4056
« Reply #5 on: January 17, 2017, 10:19:30 pm »
I don't think there is a specific ford o-ring for the IAT sensor AFAIK.
I would purchase an assortment of o-rings which comes in a variety of sizes & can be handy for multiple applications such as the Iat,map sensors,Hvac,etc,pics below.  Z
http://www.ebay.com/itm/Wilmar-W5201-270pc-A-C-O-Ring-Assortment/140792825158?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D40806%26meid%3D70cb417432dd42a7894ff142f4846a91%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D162273361960
« Last Edit: January 18, 2017, 07:21:16 am by ZSHO »
* Featured Topics
* Recent Topics
by bpd1151 | Today at 01:21:26 am
I'm hoping that that opening line is laden with sarcasm.Actually ...
Re: Updated Gallery Capabilities
by bpd1151 | Today at 01:10:42 am
I have some time off from work coming up soon. I'll have to check...
by 10sleeper | Today at 12:43:07 am
Re: For those looking for something different for a 2nd (or 3rd) car
by FoMoCoSHO | May 26, 2020, 11:23:21 pm
There is another CON if you are a DIY type...The packaging is slick bu...
Re: 802SHO 2010 Build
by FoMoCoSHO | May 26, 2020, 11:08:36 pm
Pretty sweet upgrade for us Gen IV saps even without the porting.The e...
by Gjkrisa | May 26, 2020, 09:28:19 pm
I almost bought a dodge/jeep/Chrysler product once....nah I didn'...
by GhostlyGrenade | May 26, 2020, 07:35:35 pm
They must be giving SCT devices away. There's no way people are s...
Re: MRT blues
by StinkinLinkin13 | May 26, 2020, 04:32:36 pm
We'll my four muffler setup is a winner for me. Its not pretty ri...
Ecoboosted Gallery!!
by StealBlueSho | May 26, 2020, 11:27:31 am
by 802SHO | May 26, 2020, 05:15:44 am
Re: EBPF Under New Ownership!
Re: EPP CAI
Re: Letís talk weight reduction?!
Re: Ford Recalls
Re: Brake Cooling Kit
Back to top
