Started by TX MKS-T, December 29, 2016, 06:21:00 PM
Quote from: TX MKS-T on December 30, 2016, 09:15:11 AMNo problem I'm all about the DYI's Miwiau I noticed I immediate improvement but my valves were caked pretty bad. I didn't have any symptoms prior, just came across them while repairing a bad injector. I only have 42k on the clock and have been running premium 93 octane since 28k and don't really drive it hard so can only assume there are worse than mine out there.
Quote from: MiWiAu on December 31, 2016, 10:53:12 PMQuote from: TX MKS-T on December 30, 2016, 09:15:11 AMNo problem I'm all about the DYI's Miwiau I noticed I immediate improvement but my valves were caked pretty bad. I didn't have any symptoms prior, just came across them while repairing a bad injector. I only have 42k on the clock and have been running premium 93 octane since 28k and don't really drive it hard so can only assume there are worse than mine out there.Thanks for the feedback! I will check mine this summer and let you guys know how mine look. Probably be about the same mileage by then. Sent from my iPhone using Tapatalk
Quote from: derfdog15 on December 31, 2016, 11:03:42 PMQuote from: MiWiAu on December 31, 2016, 10:53:12 PMQuote from: TX MKS-T on December 30, 2016, 09:15:11 AMNo problem I'm all about the DYI's Miwiau I noticed I immediate improvement but my valves were caked pretty bad. I didn't have any symptoms prior, just came across them while repairing a bad injector. I only have 42k on the clock and have been running premium 93 octane since 28k and don't really drive it hard so can only assume there are worse than mine out there.Thanks for the feedback! I will check mine this summer and let you guys know how mine look. Probably be about the same mileage by then. Sent from my iPhone using TapatalkSUMMER??? That is like...6 months out sir...
Quote from: MiWiAu on December 31, 2016, 11:07:29 PMQuote from: derfdog15 on December 31, 2016, 11:03:42 PMQuote from: MiWiAu on December 31, 2016, 10:53:12 PMQuote from: TX MKS-T on December 30, 2016, 09:15:11 AMNo problem I'm all about the DYI's Miwiau I noticed I immediate improvement but my valves were caked pretty bad. I didn't have any symptoms prior, just came across them while repairing a bad injector. I only have 42k on the clock and have been running premium 93 octane since 28k and don't really drive it hard so can only assume there are worse than mine out there.Thanks for the feedback! I will check mine this summer and let you guys know how mine look. Probably be about the same mileage by then. Sent from my iPhone using TapatalkSUMMER??? That is like...6 months out sir...I'm well aware, lol. First baby due in June, so I have a lot of painting to do when the weather warms up before I can get to cleaning valves. Sent from my iPhone using Tapatalk
