im not sure if sct has released anything this whole year that helps me tune this
car.it seem like they are way behind in updates.
anyway
for whatever reason
AFR BANK ONE in my car is intermittent.i can drive 20 miles without it ever reading, park the car, come back out 10 min later and its now working and reading= wt f
this is of course after it was working the night before and a brand new flash.
checked for leaks around both d/ps and all 4 sensors- none- all 4 sensors plugged in- none rubbing/bent or twisted under the car.
bank 2 sensor 1- doesn't read at all-period- but it knows cat temperature OF 700 degrees???
no other pid tables will it read on that sensor at all.
more confusion
short term fuel trim is fine
car wot is set for .80 Target but third gear starts going .90-100 even though ive commanded not to lean out???
any insight would be profound thanks
