Quote from: f8tlSHO on January 07, 2017, 09:39:34 PM
Yes I believe it is a hallman, I bought it back in 2010 from a buddy to use on my mustang turbo build that never came to life... my son came in 2011 and my daughter in 2014... so garage time has taken a pretty big hit. Still have a mustang but it is missing boost. When you said you got hose a couple posts ago I thought you were talking about the 1.5" hose to connect to the intake. I wonder if lowes sells anything that would work. I have enough hose for my reference line, as long as this crazy idea works.
The hard hose that OE uses (for the brake booster anyway) is pretty hard to find anywhere. Lowes/Home Depot/Menards all sell 1/4" ID hose and 3/8" ID hose. The brake booster line is 3/8" ID. TIP is 1/4" ID.
Just curious why you keep mentioning needing an intake line? Per the hallman instructions (
http://www.hallmanboostcontroller.com/Pro%20Series%20Installation%20Instructions%20ld.pdf) and the TiAL Instructions (
http://www.tialsport.com/documents/MV-Install-Guide.jpg) you should only need two pieces of line from your dump pipe reference.
Line 1 going from the port you tapped to the input port on the MBC. Line 2 going from the MBC output to one of the bottom air ports on the wastegate. Which you have already done
Or are you talking about the radiator hose to actually mount it on the noise maker? If that is the case, I didn't use one, so am of little help, BUT, you should be able to take the dump pipe you have (and possibly the intercooler to intake noisemaker pipe) to any autoparts store and get a section of radiator hose that will work, along with hose clamps. You would just find a radiator hose that works, and choose one with the appropriate bend, then cut it down to size.
