Miles to Empty - XSport
Started by MiWiAu, November 21, 2016, 04:37:04 PM
MiWiAu
Just an FYI for anyone curious...
I was running my tank close to empty to change fuel for my next round of tuning. I was out doing some errands today and got to 4 miles to empty, as indicated on the dash, with 8 miles to my preferred station.
I didn't think I'd make it, so I stopped at a nearby station and put in 0.501 gal to get me the rest of the way. The "miles to empty" stayed at 4 miles after putting in the 1/2 gallon. According to my trip meter, I used 0.44 gal to get from one station to the other, and I wound up going 4.7 miles after the "miles to empty" hit zero.
At my preferred station I filled up with 18.709 gallons (splashing out the fill neck) on my 18.6 gal capacity tank.
At least on my vehicle, there doesn't appear to be much fuel reserve once I get to zero.
Happy Monday! :)
2013 XSport
derfdog15
Good to know. I think my miles to empty is all sorts of messed up currently from going back and forth between pump and E blends before I made up my mind. Cause using my MPG average vs. the miles to empty I get results saying I have a 15 gallon tank even though it should be a 19 gallon tank.
I am always scared when getting below 1/4 tank on any vehicle though, especially since on my mustang the bowl in the tank is drilled out a bit, and below 1/4 tank under cornering, it can have fuel starvation. Plus crap in the tank gets in the system when its that low.
MiWiAu
Quote from: derfdog15 on November 21, 2016, 04:46:22 PM
I was running a blend previously and trying to track my consumption using my trip meter and average MPG. I could never get my consumption reconciled when I tried to compare my trip meter vs average MPG and distance to empty vs mpg. They were always off.
Then, I stumbled across the "Enhanced" trip meter in my settings menu:
Settings > Display > Trip Guage > Enhanced
Enhanced mode displays actual fuel used since reset (1.95 gal, in the example below).
If your SHO has this menu, all you'd have to do is reset your trip meter after you've topped off your tank, then see how closely your actual remaining fuel capacity and your average MPG compare to your DTE. :)
2013 XSport
f8tlSHO
Quote from: MiWiAu on November 21, 2016, 09:12:57 PM
I use this also
2013 Non PP Unleashed 93 E20 3 Bar Tune, K&N drop in 12.491 @ 110.96 120's IAT
Now tuned by ajp...looking to go faster
E30 tune on14psi full weight including 2 child seats,race like a real street car.
12.433 @110.8 140's IAT; Mustang Dyno 332hp / 386tq
r1crusher
I hate to say this but I actually ran my SHO down to 0 miles.  Yes...it will go to 0 and the fuel gauge turn red at some point prior to that.  But I did make it to a station to refuel.
So never fear...it will go to 0 and you can run it for a very short bit before you have to get your walking shoes on or call AAA for a can of gas.
:D
'13 SHO, AJP Tune w/ 3-Bar
'17 F-250 6.7 PowerStroke
'17 XSport
One of the reasons you can run it past 0 is that fuel pumps retain some fuel internally in order to smooth out variances in fuel level caused by cornering, accelerating hard, etc.  It also helps cool the fuel pump.  So it is inadvisable to make this a frequent occurrence.  OTOH, if you have no issues paying for the fuel pump out of pocket, feel free :D
On the SHO I've run 17 under zero and had about 1.25 gallons left when I filled up.
No issues turning, never any hint I was about to run out.
I had the exact data written down then I tarded out and threw my receipts away.
