Quote from: SHOurpp on December 05, 2016, 10:18:57 AM
update here
i think it was holding the start button for 2-3 secs that also contributed to the fail
now i just touch it once for on and once for off and ive had success four times yesterday for revisions.
i have a full battery and unplug the radar and shut of all heat and radio controls
moving forward
On my XSport, my push-button ignition actions don't seem to match up with the X4 programming instructions. If what you're doing is working, then keep doing it. I stumbled upon this after my second or third flash, and it has worked for me ever since. For reference, this is what I do (note step 3 & 4, specifically):
1) With everything completely off (ignition, headlights, climate, radio) I'll start the "program" procedure on the X4.
2) When prompted to turn on the ignition, I push the push-button TWICE (to turn on the ignition).
3) The tune is initialized and prepared, and prompt is given to turn ignition off, I push the push-button ONCE to turn off the ignition.
4) The prompt is given on the X4 to turn the ignition back on, but I DO NOT TOUCH ANYTHING. My car continues it's power down procedure from step 3 above, and as soon as everything powers down, the airbag light comes on, and the programming proceeds.
5) At the conclusion of programming, the X4 specifies programming complete and turn off the ignition, but my ignition is already off.
Essentially, I don't touch anything after powering off the ignition in step 3. It seems weird, but this process has worked for me for the last dozen or so flashes with no issues whatsoever. YMMV.
