I was referenced to the below article from another forum. Posted at the end of the thread, but figured the question might see more traffic here...
http://www.ecoboostperformanceforum.com/index.php/topic,5654.0.htmlLooking to do the HD brake upgrade on my 2011 EB Flex; however, I'm running into some inconsistencies with part numbers and information regarding which parts will fit with what.
I was told that the 2013+ SHO, Police Interceptor Utility, and Flex w/ HD brakes all used the same larger/thicker rotor, and revised caliper. Here are the parts that the OP spec'd versus what I spec'd
Here are the parts the OP spec'd
QuoteParts (All motorcraft except rotors and pads)
Calipers: BRCF208/BRCF209
Caliper Brackets: BRBC28/BRBC29
Rotors: Raybestos 680982
Pads: Raybestos EHT1611H
Hoses: BRHF129/BRHF64
vs. what I spec'd
Quote
Caliper
Motorcraft FR BRCF292
Motorcraft FL BRCF293
Rotor
MOTORCRAFT BRRF112 or MOTORCRAFT BRR252 or RAYBESTOS 680982
Pads
RAYBESTOS PGD1611C or MOTORCRAFT BR1611
Caliper Bracket
R&L DG1Z2B292A
Dust Shield
FL DG1Z2K005A
FR DG1Z2K004A
Possible stainless brake line
Goodridge 12348 Brake Line
Now my questions lie in the calipers and brackets...The brackets I found off the Ford parts website don't spec a different caliper bracket between right and left...just the one...And the OP specs different calipers...but it seems those are only on the SHO, and the Flex, Explorer, and Police Interceptor utility all use the calipers I spec'd. Any help would be greatly appreciated!
