I assume Randy has an Explorer? The Explorer AFE intake doesn't look like it would fit on the Taurus. I looked at a co-worker's 2017 Explorer and the hood line was much higher. The AFE's tube and angled cover is about the same height as the battery - which would clear an Explorer hood but definitely not on the Taurus. It's a shame because it looks like a much better design than the Airaid. The AFE uses the stock lower box for the cold/ram air snorkle, but also has an opening aimed at the fender for even more air flow.
The more I datalog and examine the transverse 3.5 ecoboost, the more I think the stock airbox/airfilter is a restriction when running higher boost levels. Truth of the matter is that it was intended for a 2007 Edge naturally aspirated 3.5L V6. The lid is somewhat revised for the EcoBoost engines, but mainly for a different orientation. I spoke with K&N and based on the data I exchanged with them, they said the stock airbox is going to restrict those running higher boost levels because it is limiting the airflow even with their panel filter. Their cold air intake (which is like a hot air intake) will flow more than enough though, so the same goes for the Airaid.
