ACC calibration procedure?
Started by 66 Galaxie, October 07, 2016, 09:15:47 AM
66 Galaxie
Anyone know the calibration procedure for the ACC (adaptive cruise control)??
AnotherGreenFusion
did you have to remove it from the bracket?
Have not needed to calibrate but did discover if your remove the bracket entirely without removing the module from the bracket you don't need to re-calibrate.
'15 Fusion SE 2.0 AWD
CP-E Cold Side, Hot Side, αIntake, QKspl DP & RMM | Boomba Can | Cordova TB | Synapse Gen III BOV | Levels FMIC | 160* T-Stat | Steeda STB, Sway | Flatout 5700 | SCT by Unleashed/LMS 93v11
PM me for AMSOil @ Cost
66 Galaxie
The bracket on my Flex got bent last winter when my wife went through a tough snow bank so I need to pull the bumper cover and try to re aim it.  After that it may need to be calibrated so I want to be prepared.
