Detailing, SYNC, AV, Security, Electrical, and Lighting
SYNC, A/V, Lighting, and Security Systems
Lighting
Drivers side headlight replacement
Started by Usmcsho, October 05, 2016, 07:11:27 PM
Usmcsho
Ecofreak
Full Member
Ecobooster
So just bought the SHO Used. The dealer (On there dime) has to replace the drivers side headlight due to water getting into the housing and shorting out the ballast and control module. They said it was $900+!! Anyone else have tjis problem?!
2011 Platinum Tricoat Metallic nav, BLIS, backup camera, moonroof, Sony Premium Sound. LIvernois Stage 1 with 3 bar map sensor coming soon
Forum Supporters
Re: Drivers side headlight replacement
October 05, 2016, 07:17:44 PM
We've had a couple of members experience water intrusion into the headlights, but no cracking or anything visible. Most likely it is from the bulb socket area not sealing properly. Did the dealer say what was the case on yours?
Usmcsho
Ecofreak
Full Member
Ecobooster
October 05, 2016, 07:23:13 PM
They ordered the headlight today will be in Friday I'll know the cause Friday
Forum Supporters
October 05, 2016, 07:33:45 PM
Ok, I guess they can give the old headlight to you since it's not a warranty job.
Lighting
