3 bar tune
Started by ttanaka, August 27, 2016, 04:38:23 PM
ttanaka
Looking for help.
I ordered a livewire ts and am in the process of ordering some tunes for it. I've searched all of the ecoboost forums and haven't found anything that helped a lot. I just want to make sure I am doing everything correctly.
Order a 3 bar sensor from ford.
New spark plugs
170 tstat
tun from unleashed on my livewire.
Is there anything else I am missing? I also want to know if I can run the tune and just the 3 bar sensor for now as I dont want to change the plugs and thermostat quite yet.
2015 Ford Taurus SHO non-pp no mods
Thanks in advance everyone.
Yes, tune and 3 bar sensor 1st should be fine.  But best performance will be with properly gapped plugs, and of course, a cooler TStat.  The thing with plugs, you can pull them just to check them, but they are so cheap, changing them gives you a longer interval before having to change them again :)
Please do post an intro for yourself here:
http://www.ecoboostperformanceforum.com/index.php/board,14.0.html
