gapping spark plugs
Started by Colorado-SHOBro, August 26, 2016, 12:53:14 PM
Colorado-SHOBro
what tools or techniques are people using to gap there spark plugs without touching the electrode?  I don't have gapping pliers on hand just basic hand tools  and I don't want to gouge the ground strap with pliers or anything.
TIA!!
12.8@108 @ 6,000ft DA.
I would just use a plain ole feeler gauge but make sure it will indeed measure lower plug gaps .  Z
hawkeye93
I use one of these to adjust the gap, but I use a feeler gauge to check the gap:
https://www.amazon.com/gp/product/B000CO9NSE/ref=s9_acsd_hps_bw_c_x_1
2015 Ford Taurus SHO PP 12.219@112.84
PPE catless DP, Gearhead IC, SP-534, Reische 170, 3 bar, hybrid meth system, tunes from Unleashed, Livernois, Brew City Boost & AJP
1965 Ford Mustang Convertible 289 4V/T5Z/3.55
1955 Ford Fairlane Club Sedan 272 4V/Fordomatic
sholxgt
Same exact procedure for me Hawkeye!
Years ago I broke the tip of an iridium plug using the standard gapper pictured above.  I was probably just careless, but I don't want to be stuck trying to find a replacement locally on a weekend again.
Colorado-SHOBro
Quote from: hawkeye93 on August 26, 2016, 01:19:45 PM
^that was exactly my plan.i have that tool to adjust the gap and feeler to measure. problem is the metal on that tool is so weak it bends before the ground strap does!! guess I just need to find a better quality tool and I should be set. crappy ass advance auto tools  :curse:
thanks for the posts guys
