I'm driving a taurus sho 2015 non-pp.
1. If I immediately go WOT from either a stop or a rolling start I get about 0.3-0.5 seconds of slowish acceleration followed by a few seconds of push you into your seat acceleration. I assume that's because the turbos take that long to kick in. Is it better to go easy on the throttle during the first half sec or just WOT all the way?
2. Is it "bad" (as in, confuse the ecu, "shock" the turbos, or something else) to WOT till you get to speed and then let off completely until you need to reapply to maintain speed? Or should you WOT and then back off slowly as you get close to speed?
3. If I go WOT into a turn and then let off/possibly apply some brake, and then try to WOT again as I am leaving the turn, especially from a stop (some weird on ramp designs), it feels like I have no power at all for what feels like ever the second time I WOT. Is this the nature of the turbos lagging or the doing of the ECU? I know that might sound like a reckless thing to do on a public road but it's not as crazy as it sounds, it's usually like WOT from stop for 0.5-1.5 seconds, let off completely / light braking depending on the angle, and then WOT again until at highway speed.
I'm assuming, again because it's drive by wire, going WOT is just telling the computer I want to accelerate quickly and isn't really an issue, but I'm not sure how things work with turbos in the mix, because perhaps that kind of driving is just confusing it and giving me less power or disengaging the turbos or something.
Basically, beyond the simple "turbos turn exhaust into extra power" I have no idea how they work or how the ECU works around/with them. I assume they probably take a few tenths of a second to "spool" up but again not really sure.
