1st attempt
Started by cseverens, August 19, 2016, 11:05:59 AM
My 2013 SHO did the same thing with the fuel gauge but it never ran poorly.
It just took some time after the reflash to return to the proper fuel level.
cseverens
Quote from: FoMoCoSHO on September 09, 2016, 11:17:51 AM
i'll add that it never ran poorly for me either. just the guage issue. I ended up filling it last time, and will do the same this time. no big deal. I was worried my senders were going bad!!
2013 Ford Flex Limited E/B
sholxgt
Interesting!  Glad it's more common than I thought.  Guy at SCT had never heard of the issue.
This last flash was more annoying because it ran my defrost on high fan through the whole flash.  It's not a process you can stop, so I had to just hope it wasn't going to drain the battery before completing.  The climate control was set to off prior.
Quote from: sholxgt on September 09, 2016, 11:27:20 AM
Mine did that as well from time to time.
Let's see if the SCT guys can figure it out ...
cseverens
did another datalog run and sent the info to torrie. I thought W rated tires were supposed to be good!!!! lol.
