I probably can't classify this one as an "EcoBoost", though
I ended up selling the '79 Capri I was working on as a roller, initially I planned on selling the 306 and T5 as well. Trying to get the money together to Coyote swap my '84 Capri RS. As luck would have it, the day I sold the '79, I was perusing Craigslist, and saw a fox body twin turbo kit. Listed for $700. I had to know more.
Come to find out, previous owner had 50-60 miles on the kit with a stock 302, and decided to build a 351w. His custom ground cam had the wrong firing order setup, and he scored the cylinder walls. That prompted the selling of everything.
Turbo kit (looks like an ebay special) is a pair of 50-trim wheels, .63 A/R turbine housing, .50 A/R compressor housing, 5-bolt ford housing with internal wastegates. Came with headers, all cold side piping, couplers, clamps, front mount intercooler, blow off valve, oil feed lines, oil drain lines, and downpipes with O2 sensors. I also scored an electric water pump, NIB, for $100.
Attached are pictures of all the pieces, and a mockup on the engine with the water pump installed.
