I believe so
Front Display Interface Module (FDIM)
NOTE: Without navigation shown, with navigation similar.
Item Part Number Description
1 W707628-S Front Display Interface Module (FDIM) screws (4 required)
2 10D885/10E899 FDIM (without navigation/ with navigation)
3 — FDIM electrical connector (part of 14401)
Removal and Installation
NOTE: Vehicles without navigation require Programmable Module Installation (PMI) when a new module is being installed. For vehicles with navigation, the Front Display Interface Module (FDIM) is not a stand-alone module.
For vehicles without navigation, upload the FDIM configuration information to the scan tool. For additional information, refer to PMI in Section 418-01 .
Remove the center instrument panel finish panel. For additional information, refer to Section 501-12 .
NOTICE: For vehicles with navigation, make sure not to bend the video cable when removing the FDIM .
Remove the 4 screws and the FDIM .
Disconnect the electrical connectors.
To install, reverse the removal procedure.
For vehicles without navigation, download the configuration information to the FDIM . For additional information, refer to PMI in Section 418-01 .
Audio Control Module (ACM)
1 W713809-S Audio Front Control Module (ACM) screws (4 required)
2 18C869/18C815/ 18K931 ACM (single CD/ 6-CD/ navigation)
3 — ACM electrical connectors (part of 14401)
NOTE: It is not necessary to remove the Audio Front Control Module (ACM) to retrieve the part number. For additional information, refer to Audio Control Module (ACM) Self-Diagnostic Mode in this section.
NOTE: Module configuration is required when a new ACM is being installed.
Upload the ACM configuration information to the scan tool. For additional information, refer to Programmable Module Installation (PMI) in Section 418-01 .
Remove the Front Display Interface Module (FDIM). For additional information, refer to Front Display Interface Module (FDIM) in this section.
Remove the 4 screws and the ACM .
Download the ACM configuration information from the scan tool. For additional information, refer to PMI in Section 418-01 .
Heating Ventilation Air Conditioning (HVAC) Module
1 — HVAC module electrical connector (2 required)
2 19980 HVAC module
1. Remove the Audio Front Control Module (ACM). For additional information, refer to Section 415-00 .
2. Disconnect the 2 HVAC module electrical connectors.
3. Release the retaining tabs and remove the HVAC module.
4. To install, reverse the removal procedure.
