I loaded up some PIDs in FORScan that appeared to be representative of what we were looking for and data logged them. Here are the results..
First start after adaptation and KAM reset, about 20 minutes of idling. STFTs take about 7.5 minutes to stabilize. Graphed with coolant temp.I then took a datalog on a 10 minute or so drive. Finding a decent way to map this in a graph seems challenging, but here are my attempts...
STFT Over TimeLTFT Over TimeSTFT & LTFT Over TimeI think the below graph is telling me the Bank 1 Catalyst might be toast. When I gave it a bit of throttle on this drive it smoked white/grey, just as it did when it idled, but I suspect this is left over junk in the cat from the stuck injector. Toward the end of the drive I was able to give it decent amounts of throttle without smoke. Although Bank 1 was the one that had the toasted injector, so that might be expected.
Rear O2 Voltage over time with ETC Actual (throttle plate angle)If you're not familiar, you can manipulate the graphs on the Datazap website. Clicking an item in the legend toward the bottom will add it to the graph, clicking the graph line will break out a separate axis scale. Some of the PIDs I logged weren't what I thought they were. Mainly the front O2s. Nor am I getting desired rail pressure in the log. I am getting actual rail pressure, and I did get it to 2088psi and a huge fountain and fire didn't appear under my hood, so I've got that going for me.
Let me know what y'all think. She drives nice, has power, doesn't stumble, just that occasional smoke I got, but that went away toward the end of my test drive. I'm going to play around with FORScan a bit more and see if I can get a good comparative log that includes data from the front O2s. My OBDLink MX will be here Wednesday, so I can get a bit better (faster) resolution of data out of the car.
Quote from: FoMoCoSHO on July 07, 2016, 03:15:34 PM
Yeah, you need both banks to display and there are 2 different sets of O2 pids in the OBD standards list so I have some work to do to figure it out. I'm gonna ask the guys over at scantool,net which formula they use because both banks work.
