How to run a power cable from the battery through the firewall
Started by Scott4957, June 14, 2016, 10:03:43 PM
Scott4957
Can we sticky this? I finally found a post from Lanson explaining it all and with good pictures. We should host the pictures if possible in case they get moved at some point like many have.
http://www.ecoboostperformanceforum.com/index.php?topic=739.0
2013 Lincoln MKS EcoBoost, AJP Tuned
Quote from: Scott4957 on June 14, 2016, 10:03:43 PM
Done.  Z   ;)
Scott4957
Quote from: ZSHO on June 14, 2016, 10:21:53 PM
Done.  Z   ;)
Thanks!
I ran my though the large grommet behind the cowl also. Definitely get the wiper arm removal tool. It saved me a ton of time, I was nervous trying to pry it off was going to crack the windshield.   I have some pics from the SHO I'll try to find them.
You definitely want to protect the wire once it's inside the dash. There's lots of  sharp edges inside from the dash frame support.
This is what I used to remove the wiper arm. It's about $5
sholxgt
Scott4957
Quote from: glock-coma on June 14, 2016, 11:36:19 PM
Just ordered this Amazon Prime so I have it in time for this weekends install. All parts are here!
Also make sure you mark the wiper are location with some tape so you get it back to the same spot when reinstalling.
Scott4957
Quote from: glock-coma on June 15, 2016, 01:14:19 PM
Good tip, surprisingly I actually thought of that. Now will I remember?
slurppie
My windshield has indicators where the wiper blades line up. Maybe not the intended use case but they line up perfectly.
sent from my speak n' spell using tin cans and string
2013 w/PP
Synthetic blinker fluid
Ceramic muffler bearings
