@ AJPTurbo...lol! Not true, I just want a fuel curve that matches my needs. Stoich to about 4-4.5K with enrichment increasing linearly to max around redline. In a perfect world I need is a tune that can maintain FRP over 2K the entire pull with E30
@ JCam I'd suspect you are knocking because you have
too much fuel and you are wetting the snot out of the cylinder walls. The other possibility is that you are knocking off carbon deposits from the valves that are causing hot spots and preignition.
You don't need the same amount of meth up high as you do in the midrange cause you have plenty of fuel up top with the cam spun up. So it seems to me that you'd want it enriching heavy in the area the HPFP struggles and actually tapering off as revs climb just to provide some octane/cooling and not a ton of fuel volume.
