Seeking opinions
Started by BiGMaC, April 29, 2016, 11:29:32 PM
MeanKS
if anyone has any info on this (20x10 wheels/275-40 tires) please let me know.
i'm seriously thinking about getting these, but i'm worried about fitment and possible transmission issues given the weight of the wheels (39 pounds)...
MKS-EB...
Stock wheels are 20x8's.
I am running a 20x10 wheel in the rear, & have for some years now, w/o any negative effects.
I am aware of only one person who ran a 20x10 in the front, but warned of rubbing issues when turning.
As far as weight goes, and it's perceived negative effects on the trans/drive train,  I'd be hard pressed to say that would be an issue, as the OEM wheels are incredibly heavy to begin with.
Any aftermarket wheel selected, will likely be lighter (even in a wider width) than the OEM setup.
I'd be most concerned about rubbing when turning,  with a 20x10 up front more than anything.
MeanKS
what about a 20x10 wheel with 255 40r20 tires?
that should be fine, i'm thinking w/o any necessary augmentation to the front end.
according to all websites i've searched, a 255-40 tire fits a 20x10 wheel.  i wish a 255- 45 would fit, but seems like the max width of the wheel for that tire is 9.5 inches.
a 255 40r20 is within the recommended 3% margin of change in diameter.  only down side i can see is that tire is more expensive than a 255 45r20.
MKS-EB...
I believe the 3% difference is within each other, not the factory diameter. So if they're all the same size (255/40/20) you should be good to go.
AJP turbo
255 40 20 and 255 45 20 are the same width....what are you talking about?
SCT Dealer/Custom Calibrator
Specializing in 3.5 Ecoboost
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
gladams
Look at how many foreign car manufacture company like the flower look, that they have a simulator look. I'm looking to get a close matching look for our Fusion, to match our SHO.
2013 SHO mineral gray,  airaid CAI, Corsa exhaust
Traded the 2014 Fusion Titanium for........
2012 Mustang GT sterling gray 5.0 6sp manual. Roush CAI, Noise delete kit, lower control arm brace.
MeanKS
Quote from: AJP turbo on June 23, 2016, 10:22:30 AM
I'm sure you find it hard to believe, but I doubt you know everything.
according to 1010tires a 255 45 r20 can safely handle a max wheel width of 9.5 inches, while a 255 40r20 has a maximum of 10 inches.
a tech told me that aspect ratio becomes a concern with certain tire sizes, the taller the tire the narrower the effective 'safe' width.
MKS-EB...
AJP turbo
#22
Quote from: MeanKS on June 23, 2016, 12:41:10 PM
Simply was asking what you were referring to when stating that 2 tires with the same section width of 255 millimeters were a different width. No biggie
Yes I'm aware that when a tire of the same width is mounted on a different width wheel then actual tire width will change after being mounted.
But...The tire's nominal width is the same....That's what the 255 is
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
avidmotion
I have the stock PP  flowers  with stock 255-45-20 tires. I want to run either 275-50-20 or 275-45-20 or 275-40-20 are any one combo possible on stock rim, same size front and back?
Sp542@.028, windstorm CAI, MSD coils, AO GH TUNE, GH intercooler, All Amsoil, General Gmax-rs summer tires, +PP, PP PADS,EDC rotors, Colinite 476s wax, used PPE DPs, Resonator | 3rd Cat Delete with custom X pipe, Dicunzolo Gen2 Trans Mounts|, 3 bar, stock thermostat,  TRACY LEWIS DESIGNED Team RXP, the Original oil separator.
