April 01, 2020, 09:33:26 AM
Author Topic: LPFP specs  (Read 10933 times)
Offline bamsho
  • Elite Member
  • : south williamsport, pa
  • Thank You
  • -Given: 154
  • -Received: 457
  • Ecobooster
LPFP specs
« on: April 19, 2016, 11:24:11 AM »
Hey, does anyone know the specs for the tank pump.  Just curious what the GPH and PSI are.  Thanks
Offline Gray Brick
  • Sr. Member
  • : Southern California
  • Thank You
  • -Given: 34
  • -Received: 108
  • Gray Brick
Re: LPFP specs
« Reply #1 on: April 19, 2016, 02:20:51 PM »
This would be good to know..,.
2013 Ecoboost Ford Flex
Offline FoMoCoSHO
  • Super Moderator
  • Elite Member
  • : South West Ohio
  • Thank You
  • -Given: 670
  • -Received: 1136
Re: LPFP specs
« Reply #2 on: April 19, 2016, 05:11:49 PM »
This info comes from the dealership...
2013's have a different LPFP than the 2010-12's.
1st gen LPFP run at a fixed 65PSI
2013+ is variable that runs between 51 and 75 psi.
HPFP input pressure rated for 58-101 PSI (4-7bar)
« Last Edit: April 19, 2016, 05:15:16 PM by FoMoCoSHO »
2018 Cmax Titanium Hybrid (Prius Slayer)
Needs Ecoboost
22PLE Glass Coating
2011 Lincoln MKS Ecoboost Package (Play)
AJPTurbo FFV Calibration
15 PSI, 27 Degrees, Full Rail
Full GEN V Brake Ugrade
EBC Slotted w/RED Pads
MRT Axle Back
Gone but not forgotten...
2013 Tuxedo Black non-PP SHO
2015 Bronze Fire PP SHO
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • : New York SHO
  • Thank You
  • -Given: 1889
  • -Received: 3976
Re: LPFP specs
« Reply #3 on: April 20, 2016, 10:58:18 AM »
I was able to obtain some more info pertaining to the OP question.  Z      Taking center stage and the backbone of these technology changes is Gasoline Direct Injection (GDI) and Turbo Diesel Injection (TDI) engine. To review, previous fuel injection models relied on indirect injection of the fuel spray outside the combustion chamber at a stoichiometric ratio of 14.7:1 air-to-fuel. Typical piston compression ratios were limited to about 9:1 in gasoline and 20:1 in diesels due to the limits of squeezing this finite volume of incoming air.
However, Direct Injection has completely reinvented this piece of physics by allowing for more air to enter the engine while reducing the amount of fuel required for ignition. Ultra-lean fuel mixtures as high as 65:1 have been achieved in some models while the average ratios hover around roughly 25:1 on average. This is a quantum leap from the 14.7:1  limit from which we came.
One good example of this new direct injection (gasoline) engine is found within the Ford EcoBoost. The EcoBoost model is well on its way to becoming the most popular engine in its class. The 3.5L EcoBoost achieves an impressive 355-365 hp @5700 rpm, and 350 lb·ft torque, and delivers power like no other. It contains some truly impressive engineering innovations.
From twin variable turbochargers spinning at 170,000 rpms to fuel injection pulses varying from low-pressure ultra-lean micro droplets to richer 3,000 psi squirts, this engine can make gobs of power at the mere touch of the pedal. Even the pistons have a specific concave indentation, to facilitate high turbulence within the combustion chamber for optimum fuel-air mixing.   :)
« Last Edit: April 20, 2016, 11:01:33 AM by ZSHO »
Offline bamsho
  • Elite Member
  • Thank You
  • -Given: 154
  • -Received: 457
  • Ecobooster
Re: LPFP specs
« Reply #4 on: April 21, 2016, 11:56:36 PM »
Ended up replacing both main fuel pump and fuel pump driver module.   I was only having fueling issues at WOT.  DI pressure back well over 2000 psi now and running alot better.  I think the fuel pump was getting weak, which caused the driver to work harder to increase the pressure on the pump.  Seemed to be a cascading effect.  If anyone would have to have there fuel pump replaced, I would replace the driver module as well.  It's located behind the RR seat, you will need to fold it down and pull back the carpet to gain access to it. Very simple to replace, won't pay money to have someone do it.
Offline AJP turbo
  • SCT dealer and custom calibrator 3.5 ecoboost specialist
  • Elite Member
  • Thank You
  • -Given: 133
  • -Received: 1168
  • Log Warlock
Re: LPFP specs
« Reply #5 on: April 22, 2016, 01:02:26 AM »
What were your issues at wot?
Online SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 12703
  • -Received: 4160
Re: LPFP specs
« Reply #6 on: April 22, 2016, 04:09:42 AM »
Let's see how the V10 does with the new hardware!  Hopefully the HPFP is chugging along nicely.
Offline bamsho
  • Elite Member
  • Thank You
  • -Given: 154
  • -Received: 457
  • Ecobooster
Re: LPFP specs
« Reply #7 on: April 22, 2016, 08:31:28 AM »
It started last year just after running at Cecil County last Nov.  Running V8 93 at the time.  Had small pop, then slowly got worse, then it started doing it on 91 tune.  Car also had surging in town driving.  Finally guys put the aeroforce gauge to read to DI pressure, and pump voltage.  Voltage and DI pressure were fluctuating real bad.  So took a guess and replaced those parts.   Noticeable difference and voltage and DI pressures aren't fluctuating near as bad.
Online SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 12703
  • -Received: 4160
Re: LPFP specs
« Reply #8 on: April 22, 2016, 10:19:27 AM »
Kewl :thumb:
Offline BiGMaC
  • Forum Supporter!
  • RotM Winner
  • Elite Member
  • : Gilbert - SE Phoenix Metro Area
  • Thank You
  • -Given: 1155
  • -Received: 705
  • Ecobooster
Re: LPFP specs
« Reply #9 on: April 22, 2016, 10:59:38 AM »
My symptoms were just having the car die in the road and became unstartable... But when I got my LPFP and FCM replaced I felt the car ran better than it ever had... Bet you do too... I think it takes a long time for these parts to fail and performance is affected during the entire time.
Offline bamsho
  • Elite Member
  • Thank You
  • -Given: 154
  • -Received: 457
  • Ecobooster
Re: LPFP specs
« Reply #10 on: April 22, 2016, 11:10:36 AM »
Yep I agree BigMac.  I want to take care of the issue before one day it just died, and who knows where at.  One thing I've learned about electric fuel pumps, the quick working at bad spots, so been there, done that.
Offline Blackhawk
  • Sr. Member
  • : Chicago Suburbs
  • Thank You
  • -Given: 19
  • -Received: 59
  • Ecobooster
Re: LPFP specs
« Reply #11 on: April 22, 2016, 11:33:31 AM »
Is there any solid testing to see if a upgraded LPFP running at 100psi can increase overall fuel delivery through the HPFP?  If a weak LPFP can impact fuel pressure at the rail then it seems an upgraded one could have impact.
Offline AJP turbo
  • Elite Member
  • Thank You
  • -Given: 133
  • -Received: 1168
  • Log Warlock
Re: LPFP specs
« Reply #12 on: April 22, 2016, 11:45:07 AM »
Stock lpfp can run 100 psi
Offline AJP turbo
  • Elite Member
  • Thank You
  • -Given: 133
  • -Received: 1168
  • Log Warlock
Re: LPFP specs
« Reply #13 on: April 22, 2016, 12:04:47 PM »
Im not sure that would be conclusive evidence...the voltage and pressure changes often and rapidly...you maybe be at 250 at idle and 2100 at wot
Offline Gray Brick
  • Sr. Member
  • Thank You
  • -Given: 34
  • -Received: 108
  • Gray Brick
Re: LPFP specs
« Reply #14 on: September 21, 2019, 12:15:04 PM »
So what is the lph of the stock in tank pump?
* Featured Topics
* Recent Topics
Re: Suggestions where to buy PPE catted DPs
by bpd1151 | Today at 09:30:57 AM
Please don't do this, you're jumping into a thread specifica...
Re: Buying Explorer Sport - mod help
by ZSHO | Today at 07:32:12 AM
Here are the years for comparison! Best of luck. Z https://m.carcompla...
Re: DannyMack 13 MKS "Old Man" Build and Maintenance Thread
by Dannymack | March 31, 2020, 12:57:03 PM
Pretty happy with how aggressive this thing looks so far. Especially c...
Re: New Bro
by SHOstopper | March 30, 2020, 01:55:38 PM
So my hombre is a wizard and this is the finished product. I couldn�...
Re: leak in rear windshield ?
by ZSHO | March 30, 2020, 01:05:45 PM
Fingers crossed for ya! Z...
Re: F150 Boost pressure feels limited
by Defhd10 | March 30, 2020, 10:46:51 AM
The Dealership did it.  It most likely corrupted the ECU with the...
Re: SBS 2016 Taurus SHO Build Thread
by StealBlueSho | March 29, 2020, 04:45:29 PM
https://uploads.tapatalk-cdn.com/20200329/667e0cfc909d60d4096ca5aa46f0...
Re: 2013 Ford Edge SEL 2.0 EB Transmission Relearn Process:
by SHOdded | March 29, 2020, 03:55:50 PM
Not many Edge owners on here, not active anyway.Forscan Lite has a TCM...
New recommended spark plug
by bamsho | March 29, 2020, 03:01:20 PM
Well since FMC discontinued the SP542 plugs,  I thought the SP578...
Re: Ethanol analyzer
by WinPlaceSHO | March 29, 2020, 01:44:32 PM
Ok, my "Google-Fu" wasn't working yesterday, but I fina...
Re: SCT Friday Flash Sale, Today only 3-27-2020
by tmcphail | March 29, 2020, 10:45:55 AM
Sale has been extended to the 31st !https://mailchi.mp/unleashedtuning...
Re: NEED HELP: Changing PTU oil on Performance Package PTU
by SuperPete | March 29, 2020, 07:17:10 AM
Yep Yep......
Re: Epp hot pipes air intake help
by ZSHO | March 28, 2020, 06:30:50 PM
Yup. The original Gen1intake indeed. Z https://www.ecoboostperformance...
Re: SuperPete SHO Build record
by Macgyver | March 28, 2020, 02:04:15 PM
They have a MAF cleaner. Not sure how brake cleaner does. Although I a...
Re: BBK 3.5L/3.7L V6 70MM THROTTLE BODY for 10-19 SHO/FLEX/MKS
by Jordan | March 28, 2020, 05:21:26 AM
I've never heard of anybody having issues on the stock throttle b...
Back to top
