Started by pmezo33, April 13, 2016, 03:54:47 PM
Quote from: SHOdded on April 14, 2016, 04:05:09 PMQuote from: ZSHO on April 14, 2016, 03:53:25 PMI think you should have at least a PO740 code stored,heres a good link for ya with the symptoms associated with the TC. Z http://repairpal.com/OBD-II-Code-P0740Though a code may not always be set early enough to please the driver Here's a more in-depth look at P0740http://www.obd-codes.com/p0740another TC related code, P0743http://www.obd-codes.com/p0743
Quote from: ZSHO on April 14, 2016, 04:19:42 PMMANU Definitely agree with ya,does sound like the preliminary stages of the TC,my only gripe is how could the shop give you a valid assessment simply by a test drive and without any Diagnostic testing performed. Z
Quote from: ZSHO on April 14, 2016, 04:19:42 PMQuote from: SHOdded on April 14, 2016, 04:05:09 PMQuote from: ZSHO on April 14, 2016, 03:53:25 PMI think you should have at least a PO740 code stored,heres a good link for ya with the symptoms associated with the TC. Z http://repairpal.com/OBD-II-Code-P0740Though a code may not always be set early enough to please the driver Here's a more in-depth look at P0740http://www.obd-codes.com/p0740another TC related code, P0743http://www.obd-codes.com/p0743MANU Definitely agree with ya,does sound like the preliminary stages of the TC,my only gripe is how could the shop give you a valid assessment simply by a test drive and without any Diagnostic testing performed. Z
Quote from: ZSHO on April 14, 2016, 05:30:26 PMPmezo due apologize if i seemed a bit riled up,just did not want to see you throw away that kind of $$$$$ away,at least with Ford/Lincoln you should be in better hands especially if an issue was to arise or if the wrong Diagnosis was made,best of luck. Z
Quote from: AJP turbo on April 20, 2016, 01:40:07 PMDid you have fresh fluid and the proper fluid level checked hot and running in neutral?
Quote from: SHOdded on April 20, 2016, 01:43:40 PMLooks like this officially confirms trans issues. Let's see how long the product helps. I would do a 3x drain & fill after a couple thousand miles, see if it stays fixed. Anyway, good going, keep us updated.
Quote from: AJP turbo on April 20, 2016, 01:59:01 PMWouldnt a junkyard trans be better for a 2010 mks with 100k on it instead of a rebuild?..id be more comfortable with a used unit that hasnt has the case cracked open and human hands digging through it
Quote from: SHOdded on May 25, 2016, 01:29:38 PMChalk up another issue to torque converter failure. Any idea why the clutches failed? for a well-running car!
