Started by FoMoCoSHO, April 05, 2016, 08:11:16 PM
Quote from: polskifacet on July 09, 2017, 12:21:10 AMi was looking at your rail pressure. dips to like 1800 but fairly consistent.
Quote from: SHOwoosh on July 08, 2017, 08:05:20 PMNice logs I'll bet she's a beast. Is there a difference in the exhaust between 10-12's & 13+? I notice you're running 1.5lbs more boost but your wastegate duty cycle is less than mine. Envious I am.
Quote from: StealBlueSho on July 09, 2017, 07:47:46 AMWhy don't you give LMS a ring and order the new HPFP? You could run E85 in its full strength all day long.Sent from my iPhone using Tapatalk
Quote from: FoMoCoSHO on July 09, 2017, 12:09:18 PMQuote from: StealBlueSho on July 09, 2017, 07:47:46 AMWhy don't you give LMS a ring and order the new HPFP? You could run E85 in its full strength all day long.Sent from my iPhone using TapatalkNo interest for a variety of reasons.
Quote from: FearlessAZ on July 09, 2017, 01:10:00 PMQuote from: FoMoCoSHO on July 09, 2017, 12:09:18 PMQuote from: StealBlueSho on July 09, 2017, 07:47:46 AMWhy don't you give LMS a ring and order the new HPFP? You could run E85 in its full strength all day long.Sent from my iPhone using TapatalkNo interest for a variety of reasons.1599.99 reasons?
Quote from: polskifacet on July 09, 2017, 01:19:53 PMI wouldn't either. especially since there is no power increase unless you have more thousand + dollar mods. You could spray meth and have excellent results for 1/4 the price. You can even spray alcohol.
Quote from: StealBlueSho on July 09, 2017, 01:37:13 PMQuote from: polskifacet on July 09, 2017, 01:19:53 PMI wouldn't either. especially since there is no power increase unless you have more thousand + dollar mods. You could spray meth and have excellent results for 1/4 the price. You can even spray alcohol.True, but the extra flow would help a lot for E applications. ExtremeDI has theirs available now as well.Sent from my iPhone using Tapatalk
