Started by FoMoCoSHO, April 05, 2016, 08:11:16 PM
Quote from: TopherSho on May 28, 2017, 04:22:30 PMQuote from: FoMoCoSHO on May 28, 2017, 01:52:48 PMWow, its been a while since I've posted a log....Rev 39 E45 3rd sweep taken tonight, 2nd log on this revision.I'm using global knock...adding is a positive number, subtracting is negative.Holy crap!! How many times have you flashed your ECU memory .. ??
Quote from: FoMoCoSHO on May 28, 2017, 04:33:00 PMQuote from: TopherSho on May 28, 2017, 04:22:30 PMQuote from: FoMoCoSHO on May 28, 2017, 01:52:48 PMWow, its been a while since I've posted a log....Rev 39 E45 3rd sweep taken tonight, 2nd log on this revision.I'm using global knock...adding is a positive number, subtracting is negative.Holy crap!! How many times have you flashed your ECU memory .. ??No idea, lol. Ask AJP how many flashes his SHO had...
Quote from: AJP turbo on May 30, 2017, 04:55:37 PMQuote from: FoMoCoSHO on May 28, 2017, 04:33:00 PMQuote from: TopherSho on May 28, 2017, 04:22:30 PMQuote from: FoMoCoSHO on May 28, 2017, 01:52:48 PMWow, its been a while since I've posted a log....Rev 39 E45 3rd sweep taken tonight, 2nd log on this revision.I'm using global knock...adding is a positive number, subtracting is negative.Holy crap!! How many times have you flashed your ECU memory .. ??No idea, lol. Ask AJP how many flashes his SHO had...At least 300 lol
Quote from: StealBlueSho on July 08, 2017, 06:17:58 PMAre you monitoring cylinder head temps?Sent from my iPhone using Tapatalk
Quote from: SHOwoosh on July 08, 2017, 08:05:20 PMNice logs I'll bet she's a beast. Is there a difference in the exhaust between 10-12's & 13+? I notice you're running 1.5lbs more boost but your wastegate duty cycle is less than mine. Envious I am.
