Quote from: AJP turbo on April 16, 2016, 11:18:40 PM
Steal blue sho your WOT from a stop is kinda interesting.....Your throttle is closing Id say because you are overboosting and load must be exceeding a torque limit....I'm not sure why you are going so much over your desired boost...You are targeting about 202 kpa but your were boosting to 225 and even 250kpa
Your throttle closings are weird tho, the timing is weird...Your throttle closed before you hit 2nd...Usually your boost spike won't happen til after the shift and then your throttle would close a bit
Some things are hard to deduce because only torrie knows what he is doing in the tune.
And you are leaning out a little more than I would like to see...Surprisingly though, there wasn't much knock sensor acivity....Your fuel pressure isn't terrible for the load you were spiking to. You drop to around 1300 psi fuel pressure which should be enough to maintain AFR but you went to .88 and .90 lambda which I wouldn't like....I've had fuel pressure as low as 700 psi and maintained AFR. You don't and your STFT's spike. So I don't know why you went lean. You were commanding .80 lambda....That is LAMBSE. So if you have fuel pressure, and you do, you should be pretty close to what's commanded and you aren't.
Thanks for the in-depth analysis. I ended up sending Torrie a couple sets of datalogs after I return the car to stock, he said they would be useful. After which he sent me a new tune that was pretty conservative. Working back and forth a bit he seems to be bringing the load up slowly with each revision. I can't speak highly enough of this guy, he has the patience of a Saint.
My data logs are looking cleaner, AFR is being maintained better at around .80 with a slight jump to .85 for less than a second in first gear, STFT are not spiking as high around 1.08, and fuel pressure is keeping up better. Of course all that said he is keeping my loads around 1.70 with peaks around 1.76... So a bit more conservative. Seems every revision at this point adds more load but keeps my AFR under better control.
Although there at two trends I am noticing and I think you hit it on the head and Torrie is working through them...
One is I keep boosting way over desired. Each tune at this point seems to bringing those in line with each other slowly, but I am still seeing some big deltas.
Two is bank 1 keeps running considerably leaner than bank 2. I would doubt this is normal? The PCV sits on top of bank one, not sure if it is leaking or maybe a clogged injector? Vac leak? I am not throwing codes though.
In short, Torrie seems to be feeling it out and being very patient with me.. Sent him a set of logs last night at 1030, had a response by 1045 with an adjusted tune.. Talk about turn around times...
