TIAL BOV & EPP HOTPIPES
Started by zamirlihari, March 21, 2016, 05:17:55 PM
Here's a quick video with the Tial-8psi BOV & EPP Hotpipes in action while power braking it and you will notice that the bov stays open at idle or park until you give it gas which makes it close,guess thats the way it was designed and once agaiN big Thanks to Mike over at Ecopowerparts for all his help and support,truly outstanding to say the least.  Z     :thumb: :thumb:<iframe width="560" height="315" src="https://www.youtube.com/embed/HWCgElUB3wU?rel=0"
makoskey
Cant wait till I can put mine on. Hopefully this weekend!
Livernois DPs, 91 octane V8 tune 160tstat
Magnaflow CB
Sabtaj1
Perfect.  Thanks for posting.  I have to heavy of a spring. It's closed all the time. Lol
13 Eco flex.
Quote from: Sabtaj1 on March 21, 2016, 07:42:31 PM
Glad i could help ya out,also did you install the gasket on top of the Flange? Z   :)
Must.....resist.......shiny.........wicked sounding.........awesomeness.
I thought I was past parts solely for visual and audible fluff..
But damn, those pipes and that Tial look pretty sweet.
Quote from: FoMoCoSHO on March 21, 2016, 08:13:49 PM
FoMoCo coming from you it must be a true compliment,thanks.  Z   :)
Sabtaj1
Yes. Gasket installed.  Too heavy of a spring. I know forsure now.  Thanks
13 Eco flex.
Scott4957
Its just because its car porn, think with your head man, the one on your shoulders! BRB.....gotta get some hot pipes and Tial's!
2013 Lincoln MKS EcoBoost, AJP Tuned
Z.... Did you still have to keep the rear OEM box plugged in to avoid throwing a DTC? .. Where did you put it?
Quote from: BiGMaC on March 21, 2016, 11:31:08 PM
I still have the rear bov plugged in and its currently zip-tied next to the purge valve,need to splice the wires in order to place it in a better,safer spot,need to also do some organizing of the T-bolt clamps and ordered some wire looms for a much more sexier appeal,my only gripe is that the meticulous,diligent side if me  wants things perfect and cannot see a dirty,cluttered engine bay,guess you can call it ocd,LOL.  Z
Thanks Z, great video.
Mine if I share it?
Quote from: EcoPowerParts on March 22, 2016, 01:30:56 PM
Mine if I share it?
Mike anything for ya,its my pleasure.  Z    :)
I basically wanted to give a quick update and everything is working smoothly with no codes set and could not be be happier with the setup,FYI anyone considering this install found it essential and convenient to have the proper tools such as a mini 1/4 ratchet perfect for tight spaces.areas along with a small 1/4 extension and 8 & 10 mm sockets and  handy mirror to verify that the hoses and clamps are  aligned properly especially by the rear turbo inlet and lower cac inlet hose,also a Big thanks to BiGMaC Excellent DIY.  Z  :)
