May 31, 2020, 12:00:19 pm
Author Topic: FOB Battery Dead  (Read 4339 times)
Offline Auggie
  • Full Member
  • Maple Grove MN
  • Thank You
  • -Given: 1
  • -Received: 3
  • Ecobooster
FOB Battery Dead
« on: March 07, 2016, 06:18:25 pm »
FYI. I have a 2015 SHO and I thought that I would find out how to start the car if the FOB battery was dead because my wife drives the car 90% of the time. I read the owners manual and removed the key from the fob. It then said to insert the key in the slot on the steering column or in the slot in the center council. I do not have either slot so I called Ford and they don't have a clue. It gets cold here in MN so this would be good to know. Does anyone or has anyone ever had to do this ?? If so could you answer this question and get back to me. I tried to post this question on the "SHO Form" but for some reason I am no longer able to post or reply ??
    Auggie
Offline FoMoCoSHO
  • Super Moderator
  • Elite Member
  • South West Ohio
  • Thank You
  • -Given: 696
  • -Received: 1156
Re: FOB Battery Dead
« Reply #1 on: March 07, 2016, 06:34:20 pm »
Slots on both of mine in center console closest to driver.
2018 Cmax Titanium Hybrid (Prius Slayer)
Needs Ecoboost
22PLE Glass Coating
2011 Lincoln MKS Ecoboost Package (Play)
AJPTurbo FFV Calibration
15 PSI, 27 Degrees, Full Rail
Full GEN V Brake Upgrade
EBC Slotted w/RED Pads
MRT Axle Back
Gone but not forgotten...
2013 Tuxedo Black non-PP SHO
2015 Bronze Fire PP SHO
Offline BlueSHO
  • Elite Member
  • Crete, ILliNoIS
  • Thank You
  • -Given: 123
  • -Received: 107
  • Ecobooster
« Reply #2 on: March 07, 2016, 06:42:18 pm »
My 16 SHO has the slot under the center armrest closest to the driver. Has a small flap over it
2016 SHO Blue Jeans
2001 Lightning
1996 Mystic Cobra
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • New York SHO
  • Thank You
  • -Given: 1932
  • -Received: 4057
« Reply #3 on: March 07, 2016, 06:49:24 pm »
Welcome aboard the EBPF Partner,there is a key backup slot in the center console compartment,with the buttons facing the rear of the vehicle and the key ring up,place the key into the backup slot,with the key in this postion press the brake pedal,then the the button to switch the ignition on and start your vehicle,hope this helps any and please introduce yourself under introductions and best of luck. http://www.ecoboostperformanceforum.com/index.php/board,14.0.html Battery is a 2032.  Z
« Last Edit: March 07, 2016, 07:07:33 pm by ZSHO »
Offline BiGMaC
  • Forum Supporter!
  • RotM Winner
  • Elite Member
  • Gilbert - SE Phoenix Metro Area
  • Thank You
  • -Given: 1151
  • -Received: 705
  • Ecobooster
« Reply #4 on: March 07, 2016, 08:19:28 pm »
Good advice below... Better yet, the cost of a battery a year is worth the grief factor if it dies... BTW my SHO is a DD and after about 18 months I got some erratic behavior from the fob which a battery change fixed.
2013 Taurus SHO nonPP - All Ford factory options, 3BAR MAP, LMS v8 tune (mods for 3BAR, DPs, and T-stat), Paint & plastic correction, CQuart finest all exterior surfaces, limo black window tint,VLED Triton switchbacks, Daytime BrightLites switchback DRLs, full interior and exterior LED conversion, Lamin-X charcoal blackout tail lights and reflectors, PPE catted and coated downpipes, EBPP coated hotpipes with BoVs VTA, MDesign CAI
2013 F250 CC Lariat 6.7EB Diesel -stock
Offline Dxlnt1
  • Elite Member
  • Los Angeles, CA
  • Thank You
  • -Given: 118
  • -Received: 128
  • SHO-NUFF
« Reply #5 on: March 07, 2016, 10:40:25 pm »
« Last Edit: March 07, 2016, 10:44:42 pm by Dxlnt1 »
2011 SHO, 3 Bar 93 LMS stage 4+x, ACES IV, 170 T-stat, PPE Catted DP's, Alpine Sound system, Touch screen HVAC controls, full window tint
Offline Auggie
  • Full Member
  • Maple Grove MN
  • Thank You
  • -Given: 1
  • -Received: 3
  • Ecobooster
« Reply #6 on: March 08, 2016, 04:20:25 pm »
OK, I think I have got this figured out. The key in the FOB is only used to open the car door. Our car has the numbers on the door but if I forget the code I can always use the FOB key. And like you all said is to insert the FOB in the slot in the center council. Here's how I think this works? As you all know when a battery doesn't have enough voltage to operate the doors or start the engine the battery voltage is not at "0". SO when you put the FOB in the slot there must be a sensor there that will read low voltage and allow a person to step on the brake and push the button and start the engine. Thanks to you guys for your posts and I like the idea of just changing the battery once a year for good insurance.
    Auggie
Offline Dxlnt1
  • Elite Member
  • Los Angeles, CA
  • Thank You
  • -Given: 118
  • -Received: 128
  • SHO-NUFF
« Reply #7 on: March 08, 2016, 07:11:35 pm »
Perfect time to test it. Remove battery from fob and see if car starts. Would be good info
Offline Auggie
  • Full Member
  • Maple Grove MN
  • Thank You
  • -Given: 1
  • -Received: 3
  • Ecobooster
« Reply #8 on: March 08, 2016, 07:39:07 pm »
OK, I will do that and get back to you guys.
    Auggie
Offline Auggie
  • Full Member
  • Maple Grove MN
  • Thank You
  • -Given: 1
  • -Received: 3
  • Ecobooster
« Reply #9 on: March 09, 2016, 11:06:54 am »
Ok, I did what Dx suggested. I removed the battery and slid the FOB into the slot in the center council, pressed on the brake and pushed the start button, nothing? I removed the FOB and tried it again but this time I slid the FOB into the slot with greater force. The FOB went in deeper and I could feel something give. I stepped on the brake, pushed the start button and the engine fired right up !! There must be a switch in the slot that activates the starting system which would be a whole lot smarter then a low voltage sensor just in case the FOB battery was in fact at zero voltage. So disregard the BS that I posted in post #7.
    Auggie
Offline Dxlnt1
  • Elite Member
  • Los Angeles, CA
  • Thank You
  • -Given: 118
  • -Received: 128
  • SHO-NUFF
« Reply #10 on: March 09, 2016, 11:53:15 am »
Awesome info. So now WE ALL KNOW! Thanks for the test and results!
Offline Auggie
  • Full Member
  • Maple Grove MN
  • Thank You
  • -Given: 1
  • -Received: 3
  • Ecobooster
« Reply #11 on: March 09, 2016, 11:55:55 am »
You bet.
  Auggie
* Recent Topics
Re: Weight reduction and the rules
by 76fomoco | Today at 09:44:21 am
interesting, our track will not let you have a co-rider in anything 14...
Re: SHO Puddle Lamps
by StealBlueSho | May 30, 2020, 05:57:24 pm
old post I know, but the LED puddle lamps I bought last year are on th...
by SHOdded | May 30, 2020, 10:00:26 am
Nice!...
Re: SCOA Official Member!!!
by bpd1151 | May 30, 2020, 07:19:15 am
Got mine recently as well!!! Thanks to RP and all the fellow SCOA Boar...
Re: Ranger Performance Tune From Ford
by SHOdded | May 29, 2020, 07:45:46 pm
Since Ford wants to provide a warranty with the tune, they are not gen...
Back to top
