Factory rear camera install in car built with the dash display but no camera
Started by jimmyducati, January 22, 2016, 07:10:21 PM
jimmyducati
My SHO was built with the in dash display but does not have the rear camera option, just a cheap piece of plastic under the spoiler where the camera usually is. Does anyone know if I only need to buy the factory camera to install or will I need to run the wiring harness from the trunk all the way to the dash?
2010 White SHO w/two tone interior
2005 Ducati 999s  (the daily ridder)
1998 Ducati 916  (the beauty queen)
1995 Ducati 900ss (the track terror)
1978 Harley Davidson Shovelhead
jtoddk98
Didn't know that was possible. I though the SHO came standard with a backup cam
jimmyducati
I must have the only one.. I may just take out all of the trunk carpeting to look for a camera wiring harness.. Anyone have a picture of what I may be looking for harness wise?
I will need to look for ya but are there any kind of camera settings on the screen,also did you try removing that cheap plastic by the spoiler to see whats inside there and try removing the carpet inside the trunk to check for a harness connector,those wires should lead to the BCM on the drivers side trunk area,here's the link for the camera.  Z     http://www.tascaparts.com/ford/taurus/ag1z19g490b/2010-year/sho-trim/3-5l-v6-gas-engine/electrical-cat/electrical-components-scat/?part_name=rear-camera
Quote from: jimmyducati on January 22, 2016, 07:10:21 PM
Have you looked at your build sheet?
Cars do come from the factory with missing or incorrect options from time to time.
jimmyducati
Just checked the window sticker and build sheet, no mention of a camera.. It has everything but PP and backup camera.
The carpet in the trunk on the inside of the lid is really on there good, I'll have to wait til I'm at home and have my tools to get it off and check for a harness.
No selections that I have ever found on sync that looks like it controls a camera.. Although I have never looked specifically for camera functions there
jtoddk98
CL Donttry
I would take it to the dealer I'm pretty sure that all SHO's came standard with backup camera? Are you the original owner, maybe the previous owner either took it out and/or in accident?
Dbad1
2012 Taurus SHO modified, K&N CAI,3bar,LMS thermostat, NGK gapped plugs, Unleased DP, LMS Thunderstorm Cat back,LMS 4 plus tune, EBC slotted cross drilled rotors, MGP caliper covers, SHO hood graphics, Chrome grill inserts, Continential Purecontact tires
2010 BMW 528 Xdrive
2015 GMC Sierra SLE
-MANU think it says (if equipped)both on the Owners manuel and brochure.  Z
pg 20 of the brochure under LIMITED & SHO trim show the Rear View camera as standard.  The Owner's Manual covers all trims, so they have to say IF EQUIPPED, which I find is kinda bogus for the owner.
Quote from: SHOdded on January 23, 2016, 06:56:44 AM
You are correct because your da man,also the reverse sensing system came standard on the Limited only!! Btw getting hit by this storm at the moment,need to get some coffee so lets see how she does in the snow.lol  Z    :)
Here's the link for the harness for the back up camera if not supplied,also you will need to have it reprogrammed and calibrated at the dealer with IDS software in order for the guidelines to function properly while the vehicle is moving in reverse.  Z        http://www.rockauto.com/catalog/moreinfo.php?pk=3422097&cc=1445050&jnid=608&jpid=0
       FORD    2010    TAURUS    3.5L V6 Turbocharged    Electrical-Connector    Back Up Camera Connector
Price
MOTORCRAFT WPT1130 {#AU2Z14S411BNA}  Info
Leads: 8 (Only 3 Remaining)
$26.79        http://www.rockauto.com/
I just wanted to give an update and unfortunetly some models did not come with a rear camera that particular year,in order to add a camera its followed by a hefty price tag,not sure if its quite worth it.  Z         http://www.emeraldintegrations.com/ford-taurus-oem-rear-view-backup-camera-system.html
jimmyducati
ZSHO, the owners manual for the 2010 SHO specifically lists the back up camera as standard equipment... The website you listed just says it was an option on some models. I called the dealer I bought the car from and they suggested that I call back when service is open and ask to speak with the service manager. He didn't think it was a far fetched idea at all that the dealer might install the camera at no charge, "standard equipment is standard equipment" he said. Its obvious that this was a mistake on the assembly line, so with any luck I can get them to put it in for free! If not, ill just put it in myself and go to rock auto for parts.
