Started by zach_435, January 21, 2016, 05:26:29 PM
Quote from: FoMoCoSHO on January 21, 2016, 05:52:51 PMZach, can you give us some feedback on what it took to get the height and the ride dialed in, how it drives normally and when pushed hard, etc?
Quote from: ajpturbo on January 21, 2016, 06:16:22 PMDo people tinker with their coil overs that frequently ?....dont you need an alignment everytime u change the height?
Quote from: FoMoCoSHO on January 21, 2016, 06:18:58 PMQuote from: ajpturbo on January 21, 2016, 06:16:22 PMDo people tinker with their coil overs that frequently ?....dont you need an alignment everytime u change the height?As much as you play with your tune I can see coil overs driving you bonkers, lol.
Quote from: ajpturbo on January 21, 2016, 06:28:46 PMQuote from: FoMoCoSHO on January 21, 2016, 06:18:58 PMQuote from: ajpturbo on January 21, 2016, 06:16:22 PMDo people tinker with their coil overs that frequently ?....dont you need an alignment everytime u change the height?As much as you play with your tune I can see coil overs driving you bonkers, lol.I would just lower it and forget it...im ignoramus...i dont quite get it...so its an adjustable strut...
Quote from: ZSHO on January 21, 2016, 06:46:50 PMWelcome aboard Zach,so essentially your utilizing the stock springs with aftermarket struts and shocks on your 15 SHO correct? not sure who makes the struts but are they compatible with the Performance package? great pic's and hopefully the ride is the same. Z
Quote from: Vortech347 on January 21, 2016, 06:49:11 PMQuote from: ajpturbo on January 21, 2016, 06:16:22 PMDo people tinker with their coil overs that frequently ?....dont you need an alignment everytime u change the height?This is correct. Whats even more challenging is very few people actually correctly dial in their aftermarket coil overs by corner balancing. Its easy to see this when at open track events. Usually the cars that can't get around for s*** just "bolted" them in.
