Killed the tranny
Started by Wuagwan, January 18, 2016, 09:09:16 AM
Wuagwan
Hi all,
I have killed the transmission on the flex and thinking since it's down I was looking at what upgrades to do to it. I am running a Torrie tune with the firm shifts. it has 70k miles and I have found the weak link in the front CV shafts as I have split that in half. I was running 100+ mph for 80 miles or so I'm sure I over heated it. came to the 1st stop of the interstate and it wouldn't go played with the paddle shifters and got it off the road but now it won't move till I start shifting between 1-2 with the paddles at 3k rpm then it moves couple feet and slams into reverse. so now time to fix another weak link but have no clue with these new transmissions. any help would be appreciated
Thanks,
Ashby
What year eb flex?  Sounds like the trans overheated.  Were the ambient temps high, or significant high load situations occurring?  There are no available upgrades as yet for these transmissions.  You might be best off taking it in for expert rebuild.  Might consider a cooling upgrade like with the SHOs.
66 Galaxie
SHO performance package tranny cooler upgrade should be a pretty simple bolt on. There is a DIY here on the forum.
Wuagwan
sorry it's a 2012 EB with titanium package (not sure that has any factory upgrades) yeah was thinking better cooler. don't have anything to check temps as of now,need to get something to track temps.
thanks for the quick replies,
Ashby
Torque Pro provides trans temp readings.  The custom PIDs will help you monitor that and many other parameters.
Brucelinc
Wow!  Would simply running fast for 80 miles in 6th gear overheat the tranny?  We drove across South Dakoka last fall where the limit is 80 MPH and we typically were north of that by 10 or so.  I never saw temps over the high 190s.  Monitoring temps is a good plan but I wonder if overheating was the issue.
Gray Brick
Is it the PTU or transmission that is broken?
The trans on my Flex has a small cooler from the factory but doesn't continue to heat up at speed.
2013 Ecoboost Ford Flex
There is a small group of parts that can be added as an "upgrade" to the trans...you'd have to join a Facebook page and ask there...ecoboost enthusiasts...Guy on my page just built one a couple months ago
These guys say 6f55, but mainly talk about the 6f50, so IDK.
3 Year warranty
Maybe give them a call?
http://www.smartpartsauto.com/automatic_transmission_6f50.html
66 Galaxie
If you have an iPhone you can monitor trans temp and other things including
tire pressure using ForscanLite.
Wuagwan
well I called about the smart parts transmission and they don't build them anymore, he said it was such a small market they have stopped building them....GRRRRRR
ok so what to do next.
the shop that has it say's $3,500 and they will rebuild it, seems from ford they are $4,200
thanks for the help if anyone has more suggestions let me know
Thanks again,
ashby
r1crusher
Quote from: FoMoCoSHO on January 18, 2016, 06:06:07 PM
Zip kit (whatever that means)
http://www.sonnax.com/parts/3743-zip-kit
Sonnax are good...I've used their kits/components in the past with good results.
'13 SHO, AJP Tune w/ 3-Bar
'17 F-250 6.7 PowerStroke
'17 XSport
66 Galaxie
Quote from: Wuagwan on January 20, 2016, 12:27:53 PM
Did they say anything about what they feel killed it?  Overheating or ??
Thanks again,
ashby
