Cleaning the MAP Sensors - where and how many?
Started by 93Cobra, January 15, 2016, 12:39:41 PM
93Cobra
I need to clean the MAP sensors on the SHO and I found just two - by throttle body and on top of engine. Are there only these two? I wanted to shoot some MAF sensor cleaner on them and clean off. I don't run a catch can and I also run an oiled filter, so they most likely need cleaned. My gas mileage has dropped from 24/26 to 21, so I figured now was a good time to have a look. Car has 31k miles.
There are two map sensors,personally like to clean them at every oil change.  Z
Do you have winter gas in your area?  That can cause a 10% mpg drop, easy.  But getting into a routine with MAP cleaning is a great idea.
Quote from: ZSHO on January 15, 2016, 01:10:22 PM
Damn Z..im into taking care of a car also....i even change brake and clutch fluid and power steering fluid on cars that have that but every oil change lol...not gonna hurt but the reason oil never really causes a problem for map sensors is oil has no effect on the diaphragm...the amount of deflection  of the diaphragm is transferred to the transducer which gives an electrical reading....on a maf sensor the oil can insulate the element wires which will require a different current to heat the wires to the required temp
93Cobra
Thanks!! The ecoboost F150 folks are cleaning theirs (3 of them) very often and it really helps with the idle and gas mileage.
Yes, I do have winter gas here, but this issue of poor gas mileage has been around since the summer. I do know that degradation of gas mileage on these engines is indicative of an issue(s), so I figured I would start with the MAP sensors tomorrow since my air filter was just cleaned/oiled. I actually switched from K&N filter oil to Green Filter oil which is actually safe for the electronic sensors. I know that new spark plugs are in my very near future since I already have 31k miles on the factory plugs. I just wasn't looking forward to changing them.
Quote from: 93Cobra on January 15, 2016, 02:57:14 PM
Thats very debatable...the 02 sensors constantly adjust to ensure a perfect commanded mixture.
Where are the 3 map sensors? ...interesting...im curious ...so there is the map and tip sensors..where is the 3rd?
93Cobra
Same as SHO, but the third is right at the air box.
Pretty sure that is just a temp sensor, same as we have.
93Cobra
Right - on 2012 and newer trucks, it is a MAP sensor.
I found a pic and it looks like a map sensor....seems pointless.....but id say the purpose is to have a barometric pressure reference for atmosphere....the tune does have items that address it
93Cobra
Cleaning of these MAP sensors has proved valuable to the f150 owners, so I will be doing my SHO tomorrow.
Some people tell me their airfilter made a difference....i usually prefer hard evidence...havent seen any from spraying down a map sensor...how does it affect the internal diaphragm of the sensor?
93Cobra
Issues they had before are gone after the cleaning- you figure it out.
Quote from: 93Cobra on January 16, 2016, 09:31:32 PM
I just figured it out...They made an erroneous correlation to the percieved subsidence of symtoms
