Hey all, just curious if anyone here has run into these with their SHO at all and what you might have done to fix it? I am out of warranty on my 10' so I am currently in work on this issue with the TB. I had changed the TPS last night and it made it worse, but pointed out the actuator was at fault finally, rather than it just being stuck open as the P2111 stated. I bought a new actuator (Doorman) and will put that on and see where it gets me on this TB. If this doesn't work, I will replace the entire TB, but if anyone has heard of this and can help me eliminate or add a troubleshooting step somewhere, any help is greatly appreciated.
***Edit- It started to have this happening after my battery had finally died, so I replaced it. Is there a relearn that I may have missed that would throw my throttle trims out? Thanks!
