Updating Tuner
Started by KonaTheWhale, November 28, 2015, 05:36:46 PM
KonaTheWhale
Would there be any benefit to updating my Livernois tuner? I got thinking the other day and wasn't sure if they keep pushing out updates to revise the tunes or once you have it that is all. By updating I mean to connect it to your computer and run the tuner update application. I haven't done any other modifications and have had it since the spring
2011 Ford Taurus SHO non PP Kona blue, Livernois 93 octane 3 bar tune, PPE catless downpipes, muffler delete, 160* stat, K&N drop in filter, VTA mod, rear end lowered, 15% tint, EBC brake upgrade
bamsho
What are your last versions of the tunes for the '10-12 do you have?
Only needed to do if you request for tune changes.
slurppie
I update the update software periodically and check for hardware updates. As the other gents mentioned, the tunes themselves are only updated based on request and if available.
Sent via my Speak and Spell
2013 w/PP
Synthetic blinker fluid
Ceramic muffler bearings
Larrylu
My MyCal touch is so old (bought it in '11) that LME has to email me tune update files and yet they still support me with updates and no complaints. Great customer service.
2010 Stl Bl Met, Loaded, non PP, LMS 4+X, K&N drop in, 170 T-stat, 3 bar MAP, SP534
Quote from: Larrylu on November 29, 2015, 08:56:17 AM
Lol a dinosaur tuner lol.....and no need for a pat on the back for doing the right thing...glad they still supported the customer lol
TSS
Ditto for me. I have the MyCal touch too which I got in 2012.  LME (Jaimie) continues to make it all work for me with updated tunes.
Larrylu
Quote from: TSS on November 30, 2015, 09:44:54 AM
One good thing about the old MyCal touch is that it holds a bunch of tunes. I can't remember the limit, but some over the top number like 50.   I should count but I think I've got at least 10 on there.
Remove & replace the SD card (with same memory capacity,  or larger) & you can hold even more.
Larrylu
Quote from: bpd1151 on November 30, 2015, 12:12:41 PM
Oh yea, I forgot about the remove able memory card. It's actually been a pretty good all round tuner!
Livernois Motorsports
Thank you for the kind words!
Yes the others are correct on the tuner updates.  The only thing it may find periodically is an updated firmware which typically is to add support for newer VINs such as adding the 2015-16 vehicles to the list of supported VINs.  We would have to actually setup updated tunes specifically for your serial number which is a case by case basis.
