2 into 1 into 2
Started by Capri83RS, November 08, 2015, 06:18:32 AM
Capri83RS
I've looked at the threads pertaining to the one member that utilized a 3" single pipe, but the site recommended I start a new thread instead of posting in another.
Without jacking up my car and taking measurements myself, does anyone have some fairly exact measurements of the stock cat-back and good pictures of the underneath?  I'm contemplating building my own cat-back and pairing it with a good set of catted down pipes next summer, but I'd like to draw it up and see what it looks like on paper.  Cost-wise, I'm looking at around $700 for materials and I'd fab it up in the garage.
I figured on using 2.5" dual into 3" single y-collectors at each end, a single (maybe a pair) 3" in/out race bullet(s) in the center, and a 2.5" in/out race bullet on each side at the rear, with 3.5" tips at the bumper.
I fabbed up the exhaust on my '79 Capri using a pair of the 2.5" in/out race bullets, and it's obnoxiously loud.  I did expect that, with a healthy V8 though, which is why I'm considering 1 or 2 mufflers in the center section.  That should help with the volume and the tone, while still allowing the turbo to breathe properly.
1984 Capri RS
1991 F150 4x4
2013 Mustang GT Track Package w/ Recaro's
2014 Taurus SHO
I cut factory exhaust in two sections,from cat back to the resonator its 41 inches,from resonator to the rear muffler its roughly another 58 inches,so basically a grand total of 99 inches from cat back,hope this helps any.  Z
MDesign Performance
http://www.ecoboostperformanceforum.com/index.php/topic,3994.msg62625.html#msg62625
You might be talking about my custom catback, it is still available if you are local and would like to save cost and time on most of the work.
Key notes if you do decide to go your own route, the mufflers make all the difference in the end in regards to sound levels. I would recommend Borla or Corsa mufflers, or even the OEM mufflers with a single high-flow resonator in the system similar to our design.
sales@mdesignperformance.com
www.mdesignperformance.com
Capri83RS
Quote from: ZSHO on November 08, 2015, 10:03:05 AM
Thanks, those will be a huge help, I think!!
1984 Capri RS
1991 F150 4x4
2014 Taurus SHO
Capri83RS
Quote from: MDesign on November 09, 2015, 02:25:22 PM
Unfortunately, I'm not local.  That's a good price, too!
I was contemplating the Dynomax race bullets, as they are going to be under the car where you can't see them and where it's hard to clean/polish, especially in the winter.  Those are what I have on my '79 Capri (originally built it for my '84 Capri, but swapped the entire driveline into the '79).
2.5" http://www.jegs.com/i/Dynomax/289/24215/10002/-1 (what I currently have on my Capri)
3" http://www.jegs.com/i/Dynomax/289/24238/10002/-1
I've got a set of Magnaflow tips that would be put on the end.
http://www.jegs.com/i/Magnaflow/642/35143/10002/-1
https://www.youtube.com/watch?v=qmW5XQvGLgI
1984 Capri RS
1991 F150 4x4
2014 Taurus SHO
