Ford tests splash blends on the 3.5 ECO.
Started by FoMoCoSHO, November 06, 2015, 02:16:24 AM
http://www.greencarcongress.com/2013/04/e30-20130419.html
"In a paper also presented at the World Congress, a Ford team (Jung et al.) used engine dynamometer testing to compare E10, E20, and E30 splash-blended fuels in a Ford 3.5L EcoBoost direct injection (DI) turbocharged engine"
Something I've been thinking a lot about a lot and I'm not sure has been exploited properly yet. We were just starting to test this on the 2013 when I traded it.
"Reduced enrichment. Enrichment of the fuel mixture at high-speed, high-load conditions is currently used to reduce exhaust temperature to avoid damage to engine or emissions aftertreatment components. However, enrichment also degrades thermal efficiency. Increased ethanol content enables improved efficiency by reducing or eliminating the need for fuel enrichment."
Datalog looks very, very good.  Great fuel trims, knock, etc.  Still need some insight into the spark advance setup on SCT, why the differences between SA & SAv2; seen it not just on your SHO, but others too.  Is it desired vs actual, or bank1 vs bank2 or ...
That log was last week at the track. For some reason the car hit the rev limiter and then kind of freaked out it seems. But ended up producing some interesting data.
